SovietofWashington
Post by SovietofWashington »
Same here. About 10% of the time. Most times a refresh fixes, but not always.
here is what I get:
500: Internal server error
This error is generated when a script running on the server could not be implemented or permissions are incorrectly assigned for files or directories
Troubleshooting suggestions:
Temporarily disable any rewrite rules by renaming your .htaccess file if it exists.
Ensure that any CGI or Perl scripts have at least .755. permissions.
If trying to run PHP and you get this error, you may have an invalid php.ini in your /cgi-bin, or may be missing your php.dat file in this folder.
it failed several times yesterday without ever working. Just now it failed then worked then failed then worked several times
Post by Reality Check »
I have been seeing the below on the first, and some times several clicks on a link.
This has been going on for a few days. Not sure when it started.
If I keep on refreshing it works on the second, or later, refresh.
at99sy
Post by at99sy »
i'm gettign the same error message today.
"The idea that an observation that doesn’t fit the curve falsifies the theory and requires trying out other preconceptions is naive: People are not that easily convinced to abandon or even to question their prior beliefs. The usual practice is to patch the theory and to dismiss alternatives out of hand. If patching fails, the discrepant observation is simply ignored and any gadflies who persist in mentioning it are expelled."
Does this describe anything in the economic or political realm? A human trait?
The above is from a discussion regarding stellar evolution. http://www.thunderbolts.info/wp/2013/12 ... can-see-2/
I seen that G and understand that point of view since context matters on that picture
and the position America was getting in on "affairs".
Rule number 1 to parlance speak as the earlier post warrants.
http://www.sunnycv.com/steve/WW2Timeline/Prelude08.html
http://www.independent.org/pdf/tir/tir_01_4_higgs.pdf
http://newsroom.ucla.edu/portal/ucla/FD ... -5409.aspx
The 1937 gal and "appearances" the artist who I forgot his name had a flair for subtle truths then.
If one point was not clear, two maintained traction to his view was clear as "histoire drôle"
Nous sommes dans une situation où l'on peut dire qu'à mesure que le temps passe, on se rend compte que ceux qui estimaient avoir raison trouvent
la situation de moins en moins drôle.
http://www.independent.co.uk/news/busin ... 18432.html
http://www.ucl.ac.uk/whitehallII/pdf/Wh ... let_1_.pdf
Scorn or pity was the short answer.
aedens wrote:Does this describe anything in the economic or political realm? A human trait?
Or blind to the "truth"?
Users browsing this forum: Google [Bot] and 9 guests
