vincecate wrote:I think the main misplaced confidence is that people think the Fed can control interest rates longer than they will really be able to. They have been low for the last 5 years, so people project this out well into the future. I think this is the core flaw in people's beliefs.
I noticed when stocks were dropping in June that the goons at the Fed one by one appeared in the media, emphasizing that any tapering is separate from short term interest rates and that the Fed would be keeping the Fed Funds rate at zero until 2015. That seemed to have the effect of soothing the stock market. It's pretty well understood that stock prices reflect this projection of zero percent short term rates until sometime in 2015. In other words, that is priced into the market.
So I think you're right that the stock market believes the Fed when they say they can keep the Fed Funds rate at zero until sometime in 2015. The real world is a lot trickier than being able to honor a projection or promise 2 years into the future, I would agree. The minute it looks like the Fed will be forced to raise short term interest rates due to inflationary pressures or something else, stock prices will tank, if they haven't already. Bernanke admitted this within the past month, using the same words.
Now the question is, would it even take that to turn the stock market down? Consider this chart of 2 month change in new home prices. Biggest drop since 2009. I didn't know that when making the previous post, just knew they had dropped. There are better ways to present this data and I will look for something better,
http://www.zerohedge.com/sites/default/ ... Change.jpg
U.S. NEWS
Updated July 24, 2013, 5:10 p.m. ET
U.S. New-Home Sales Surge 8.3%
Median Price Climbs 7.4%, to $249,700,
as Supply Falls to Lowest Level Since January
By SARAH PORTLOCK and JOSH MITCHELL CONNECT
WASHINGTON—Sales of new homes surged in June despite higher mortgage rates, maintaining momentum for a key sector driving the economic recovery.
New-home sales increased 8.3% last month to a seasonally adjusted rate of 497,000, the Commerce Department said Wednesday. That was the highest level since May 2008. Sales were up 38% from a year earlier.
http://online.wsj.com/article/SB1000142 ... 78508.html
Who do you believe?
I am quite sure they are measuring against prices from 1 year ago, whereas zero hedge is measuring against prices from 2 months ago. Then I see the WSJ is talking median whereas ZH is talking average.
I don't think either method is definitive without being able to look at a long term chart of new home prices, and I can't find one.
Prices should naturally rise going into the Spring selling season, then fall some in the Summer. But if prices rose massively into this Spring's selling season, then a larger than normal drop would not be anything to get excited about.
The way various factions present their data doesn't allow for good analysis. Zero Hedge has a negative bias but they are also the only good source for a lot of data, increasingly so, I would add.
John wrote:Who do you believe?
Zero Hedge passes the smell test a little better on this one. Looks like a huge drop on the chart, comparable to (or greater than, really) the end of the last bubble. 40 percent of the 2-4 year rise in new home prices has been wiped out in 2 months. If this were to continue at near this rate, new home prices will be below 2009 lows before year end.
Getting back to the discussion with Vince, if this small bump up in interest rates can have this large of an effect on the price of new homes, it may not take much more of a rise in interest rates to turn the economy and stock market over. And, importantly, together with the recent reports from the home builders of large numbers of order cancellations.
http://research.stlouisfed.org/fred2/series/MSPNHSUS
MEDIAN NEW HOME PRICES.png (18.77 KiB) Viewed 3763 times
MEDIAN NEW HOME PRICES2.png (20.46 KiB) Viewed 3758 times
Post by Reality Check »
Higgenbotham - Saturday July 27th, 2013 wrote:
This week new home prices were reported down while Ryland and DR Horton said their order books are collapsing due to cancellations. Housing stocks in general are well off their May peaks. In the last cycle housing stocks peaked in late July 2005, two years ahead of the general stock market but new home prices didn't start dropping until a year later. Things seem to be moving quickly.
John wrote:
U.S. NEWS
John wrote: Who do you believe?
When you are comparing the prices of fruit you need to make sure you are comparing the same types of fruit and using the same units of measure.
Statistical data on house prices appear as many different types of fruit.
By ALAN R. ELLIOTT, INVESTOR'S BUSINESS DAILY, Thursday 07/25/2013 wrote:
Homebuilders collapsed Thursday as investors pulled the plug after a spate of quarterly results.
PulteGroup (PHM) drilled as much as 13% lower before closing down 10%. D.R. Horton (DHI) and Ryland Group (RYL) tanked 9% and 5%, respectively.
Pulte reported a 100% increase in earnings, less than forecast by analysts. More important, its orders declined and deliveries undercut analyst views. D.R. Horton met earnings expectations, but missed on the revenue line. Deliveries and net new orders both stopped far short of analyst views.
Homebuilder stocks have traditionally rallied at the front end of housing recoveries. The group rallied for 16 months when the home market turned up in 1990-92. It rallied for another 17 months starting late in 1992. When housing rebounded in 1997-98, the group rallied for 15 months.
The stocks rallied for five full years through July 2005. Now, depending on how you count, homebuilder stocks rallied for either 17 or 19 months to their late-March peak. Has the industry reverted to its old, 15-to-17-month pattern?
H. is talking about the decline in stock prices of companies that build and sell new homes, NOT the price of new homes and Not about the stock of houses for sale..
When H is talking about orders they are talking a leading indicator that is out in the future maybe six months. When H is talking about cancellations they are talking about orders for homes months ahead of delivery.
Even though the earnings of one of these companies increased by 100% in the quarter just ended the stock tanked. Home Builder Stock prices are leading indicators and are very sensitive to the effect rising mortgage interest rates will have on profits 6 to 12 months from now.
Higgenbotham wrote: Consider this chart of 2 month change in new home prices. Biggest drop since 2009. I didn't know that when making the previous post, just knew they had dropped. There are better ways to present this data and I will look for something better,
Here we are talking about different fruit and likely different units of measure as well.
Home builder stock prices, orders from home builders, signed real estate contracts, and closings are all different types of fruit, and very different types of fruit prices.
The price of the stock of a home builder is a very different unit of measure.
Raw home sales data and seasonally adjusted home sales data are slightly different units of measure.
Calender month comparisons year to year, and month to month, are different units of measure than two month windows from mid month one month to mid month two months later.
Real Estate Sales Contracts entered into by brokers and actual sales closed ( which includes both sales closed with, and without brokers ) are are leading indicators and trailing indicators respectively, and do not match up chronologically for comparison purposes, even if you ignore the fact that one is apples and one is oranges.
More importantly than that, strange aberrations happen, for a couple of three months, in the housing market when it is widely perceived by all the market players that a long term shift in mortgage rates from historic lows to ever increasing mortgage interest rates occur.
Some low end Buyers have locked in interest rates that allow them to buy at lower interest rates for a month or two after the rate increases start. Thus a surge in raw numbers of sales.
Sophisticated high end buyers ( high home price buyers ) have stock profits they can roll in to high end, high price, housing. They are motivated to do this because stock prices are likely to fall as mortgage rates, and interest rates in general, increase. Real Estate has historically been a superior hedge against both inflation and recession if the investor can buy and hold for decades.
Sellers fearful of the negative effect middle term increases in interest rates will have on the price, and even the ability to sell their homes, will cause sellers to make concessions to sell, some of these concessions will show up in lower prices in sales contract price and/or closing prices., many such concession will NOT show up in one, the other, or either statistic as lower prices for the first months of this transition in the market.
All of these factors will result in the surge in the numbers of homes sold for some number of months, but they will also cause aberrations in the sales prices for a month or three.
The longer term effect should be more predictable as some buyers are forced out of the market at the lower end due to rising interest rates, a slowing in sales / increase in the inventory of houses listed for sale, and eventually a drop in house prices starting at the entry level homes.
All this is the normal cycle and should continue unless the economy collapses or an inflation driven false expansion takes hold.
Last edited by Reality Check on Sun Jul 28, 2013 5:27 pm, edited 5 times in total.
Reality Check wrote:More importantly than that, strange aberrations happen, for a couple of three months, in the housing market when it is widely perceived by all the market players that a long term shift in mortgage rates from historic lows to ever increasing mortgage interest rates occur.
I think that is a good point to emphasize. It wouldn't be expected that the price drops in new homes that have occurred over the past 2 months would continue at the same rate unless something unusual is happening compared to past cycles. Already, though, we have seen a lot less lag time between the peaks of the housing stocks and the first substantial price drops in new homes. At the same time, in this cycle, the housing stocks are priced lower, new home orders are lower, etc., which puts a lot of confounding variables into the mix which makes it difficult to know if that lesser lag time is significant, yet. But as noted a few months back, I think it's important to watch the housing stocks and the housing market in general to get clues as to leading indications in this economy. As you can probably tell, I was caught a little off guard by this large drop in new home prices having happened so soon.
In addition to what I mentioned above, one must be very careful when looking at changes in house prices month to following month, or even every two months, against every two following month.
Raw Aggregate figures for all home sales do not take into account variations in what types of home are being sold. Entry level buyers purchase in some months and not so much in others.
If you had a surge in entry level buyers and did not adjust the prices to normalize the data for square footage and location, you very well might see a drop in housing prices that would be misleading.
Real Estate Broker Associations make selective press releases to the media emphasizing a carefully selected mix of raw and normalized data in an attempt to spin a narrative that NOW is the time to buy.
When you realize that NOW is the right time to buy for those who need housing ( rates are going up ) then you would expect to see rising number of units and prices if the data was appropriately normalized. Supply and demand being what it is right now.
If, on the other hand, appropriately normalized data was showing the type of drop in home prices the below graph indicates, that would be stunning.
We already had this discussion in context to local affairs and peak property tax seisures.
From there, the aggregate can indicate, but not lead reality by the nose. We are just infering the
over hang as we did once before when we recanted our views on the storm wall discussions before OLD graduated
to the next level. As we also noted for reference, we gravitated abeit painfully to agree these mbs and other SIV products
will have to level off as they may of for now, and the market clears those raisons from the manure for those who venture into those
investment products.
Currently the thought into august appears to be REITs, Agency mREITs, BDCs, Bond Fund must all be decimated to make some one appear the sun will not rise tommorrow as other are waiting to buy it when a provident accurance announces itself. Well we will just have to carve out a bottom some also convey. What is needed to prevent any further credit expansion is to place the banking business under the general rules of commercial and civil laws compelling every individual and firm to fulfill all obligations in full compliance with the terms of the contract. If you have to convince a group of people who are not directly dependent on a solution of a problem, you will never succeed. Only to bureaucrats can the idea occur that establishing new offices, promulgating new decrees, and increasing the number of government employees alone can be described as positive and beneficial measures. The issue is always the same: the government or the market. There is no third solution.
A quick spin through many of the countries there reveals much instability:
Greece: currently living through a capital "D" Depression. Destitution has reached the professional classes at this point.
Italy: teetering on the edge of political collapse as politicians fight any and all austerity measures
Spain: rocked by political scandal, its banking system is now insolvent
Portugal: experiencing the flight of its younger generation out of the country
France: quickly becoming a bankrupt welfare state, as only 17 million of its 66 million citizens are working
Holland: stumbling under the highest level of private sector debt to GDP of any EU country
Belgium: struggling with the same challenges as Belgium
Germany: losing its sovereign wealth with every bailout of its clearly insolvent neighbors /taggart
Maybe they will someday be smart enough to figure out spending other people money destroys the market.
Even us who have watched from Corporate for decades are stunned and also the social darwinism as they destroy themselves with pragmatic efficencys.
"Now Morrow, who studied vibrations in mechanical structures for patterns that would portend structural failure..."
I see the "vibration analysis" guys are poking at it here. As mentioned awhile ago, it was my guess that "flutter" could be the mechanism by which the stock market would crash, so if this guy knows what he is doing (and he appears to) I'd have to say the likelihood he can be correct is high.
https://twitter.com/ukarlewitz/status/3 ... 92/photo/1
Fat buzzard or canary to earning and spread compression....
Assuming ARCP closes on both CapLease and the GE Capital portfolio, the combined company will own almost 30 million square feet with 1,253 free-standing properties. ARCP's current enterprise value is around $4 billion and once the GE Credit portfolio ($807 million) and CapLease portfolio ($2.2 billion) are rolled up, ARCP will have an enterprise value of around $7 billion. sa
One of the difficulties with Cole today is assigning a value to the shares (especially Cole Holdings)
Indeed fear and greed is pointless diatribe to Mezzanine financing of basically debt capital that gives the lender the rights to convert to an
ownership or equity interest in the company if the loan is not paid back in time and in full.
