America is used to a people who are prejudiced and use violence against minorities. We are used to juries looking the other way when it happens. This expectation would be there even if they do not. Much of the blue drive is to end the prejudice in the courtroom. I would say it would cease to be a problem only if the prejudice went away. Not likely in the short term.
- Bob Butler
- Contact:
The problem is not the legal system, but the juries.
Re: The problem is not the legal system, but the juries.
Problem #9545758 with you, Butler, is that you view whites as bad and blacks and other POCs as good. You are a moronic hypocrite. And you are going to be left on the other side of the new border when the country is broken up.Bob Butler wrote: Fri Nov 26, 2021 12:21 pmAmerica is used to a people who are prejudiced and use violence against minorities. We are used to juries looking the other way when it happens. This expectation would be there even if they do not. Much of the blue drive is to end the prejudice in the courtroom. I would say it would cease to be a problem only if the prejudice went away. Not likely in the short term.
I won't even wish you good luck with that.
Guest from Tx
This will make BB happy...Bob Butler wrote: Fri Nov 26, 2021 12:21 pmAmerica is used to a people who are prejudiced and use violence against minorities. We are used to juries looking the other way when it happens. This expectation would be there even if they do not. Much of the blue drive is to end the prejudice in the courtroom. I would say it would cease to be a problem only if the prejudice went away. Not likely in the short term.
ISIS slavery survivor is canceled for having wrong enslaver: For anyone who sees the new radicalism as an American problem, look North. The Toronto District School Board pulled out of an event with a Yazidi survivor of ISIS sex slavery—the Nobel Prize Winner Nadia Murad—because it might “offend” Muslim students. Isn’t it more offensive to imply that Muslims would be offended?
- Bob Butler
- Contact:
Not all whites are prejudiced racists. Not all use violence against minorities. These collisions we have seen recently in the courtroom are few when you compare them in numbers to the population. But I would have the law being the law. Neither some previous experience having nothing to do with the case in question, nor any prejudice, should have an effect in the courtroom. Should any split country have half with a justice system based on prejudice and oppression, I’d be quite content being in the other half.Guest wrote: Fri Nov 26, 2021 12:34 pmProblem #9545758 with you, Butler, is that you view whites as bad and blacks and other POCs as good. You are a moronic hypocrite. And you are going to be left on the other side of the new border when the country is broken up.Bob Butler wrote: Fri Nov 26, 2021 12:21 pmAmerica is used to a people who are prejudiced and use violence against minorities. We are used to juries looking the other way when it happens. This expectation would be there even if they do not. Much of the blue drive is to end the prejudice in the courtroom. I would say it would cease to be a problem only if the prejudice went away. Not likely in the short term.
Except that the BLM dystopian bottom feeder People's Republic won't be a just place. And, being stuck there, you will be faced reality for the first time in your life.Bob Butler wrote: Fri Nov 26, 2021 2:32 pmNot all whites are prejudiced racists. Not all use violence against minorities. These collisions we have seen recently in the courtroom are few when you compare them in numbers to the population. But I would have the law being the law. Neither some previous experience having nothing to do with the case in question, nor any prejudice, should have an effect in the courtroom. Should any split country have half with a justice system based on prejudice and oppression, I’d be quite content being in the other half.Guest wrote: Fri Nov 26, 2021 12:34 pmProblem #9545758 with you, Butler, is that you view whites as bad and blacks and other POCs as good. You are a moronic hypocrite. And you are going to be left on the other side of the new border when the country is broken up.Bob Butler wrote: Fri Nov 26, 2021 12:21 pm
Ukrainian President claims to have foiled Russian-backed coup plot; coup operation was days away from being carried out
https://www.msn.com/en-us/news/world/uk ... ar-AARa5Ve
This YouTube Channel seems a good source of info on Geopolitics, especially the Rise of China:
https://www.youtube.com/c/TheGeopoliticsInConflictShow
** 27-Nov-2021 World View: KKK Democrats as Fascists
Let's look at the history.
The Democrats were furious that Republican Abraham Lincoln freed the
slaves and the Republicans won the war, and the infuriated Democrats
formed the Ku Klux Klan (KKK), a militia movement that spent the next
century killing blacks and massacring blacks. However, I don't recall
that the KKK Democrats were ever called "fascist" or "far right,"
especially since America was at war with the fascists in WW II.
That was the last century. In this century, the Democrats have
continued the same KKK policies, killing blacks and massacring blacks
in large cities government by Democrats. However, we still don't use
the terms "fascist" or "far right" to describe those Democrats.
Instead, the Democrats use those terms to describe Republicans and
Trump supporters and anyone else opposing Democrat policies, and the
Democrats do that while they're killing and massacring blacks, while
they're jailing political opponents without meaningful charges, while
they're conducting massive censorship campaigns against anyone from
parents to bloggers who speak up against the Stalinist Fascist
Democrat policies.
One of the most pernicious Democrat policies has been the
indoctrination of children with Critical Race Theory (CRT) policies in
by Democrat school boards across the country. It's noteworthy that
CRT is not claimed to help "minorities," since it targets and
discriminates against Asians and other minorities besides blacks. CRT
is designed specifically to target blacks, to marginalize them, to
keep them from getting a proper education, to keep them from getting
good jobs. Slaveowners made sure that slaves never learned how to
read, and CRT is a modern day version of the Jim Crow laws to keep
blacks in their place. Keeping blacks illiterate, and telling them
that math is "racist" is the best way to make sure that they'll do as
the KKK Democrats tell them.
But you're absolutely right that not all Democrats support the KKK
Democrat policies. Indeed, it's quite possible that a minority of
Democrats do. But it's the KKK Democrats who are now in charge of the
Democrat party, led by such KKK Democrat leaders as as AOC, Ilhan
Omar, Nancy Pelosi, and White Supremacist Joe Biden.
In this sense, Bob Butler is right when he talks about "tribal
thinkers," trapped in the policies of previous generations and eras.
But he's absolutely, completely wrong when he identifies who those
"tribal thinkers" are. It's certainly not the members of this forum,
as he's claimed in the past, and it's not Trump supporters or
Republicans. Today, the term "tribal thinkers" is synonymous with
"KKK Democrats," the people responsible for far-left Socialist
policies like killing and massacring blacks, and indoctrinating
children with CRT hatred and bigotry. Those are the "tribal
thinkers," adopting the policies of last century, hoping that "The
South Will Rise Again," hoping that the blacks can be re-enslaved, and
hoping that the Democrats will win the next American Civil War.
This shows how meaningless terms like "fascist" and "far right" are.richard5za wrote: Thu Nov 25, 2021 2:43 am > Dear John, I read your post with great interest and like most
> reasonable people very pleased that the trial reached a fair
> outcome. But I was amazed at your view that the KKK and presumably
> other serious racists are members of the Democrats. The Democrats
> claim to be politically center through to socialist left, whereas
> the KKK racist position would normally be classified in most parts
> of the world as politically far right, or fascist, etc. There's a
> science called epistemology which is the study of knowledge and
> one of the important questions is "how do we know what we think is
> fact, or true, is actually fact or truth?" And if say 100 KKK's
> claim to be Democrats that doesn't make 80 million Democratic
> voters KKK. Most interested in your views?
Democrat policies.
** 27-Nov-2021 World View: Derek Chauven court trial
George Floyd's death triggered massive violence by antifa-blm fascists
across the country, supported and backed by Democrat party socialists
and KKK Democrats who, as I've said, are a minority of the Democrat
party, but who are now leading the Democrat party.
One objective of the court system, dating back to the British Common
Law system was to find the truth, but there was another equally
important objective: preventing the actions of vigilante and terrorist
groups. If a court system finds a criminal guilty of a crime, and
exacts a reasonable punishment for that crime, then the motivation of
vigilantes and terrorists has been undermined.
So it's my opinion that if there had been no court trial for Derek
Chauvin, or if the court trial had found him innocent, then he would
have been lynched and killed by antifa-blm vigilantes and terrorists,
backed by the Democrat party leadership. So the court trial saved
Chauvin's life (assuming, by the way, that he wanted his life to be
saved).
But the court system did a lot more than save his life. The trial
created a detailed record of all the evidence, pro and con, from
prosecuters and defendant lawyers, of Chauvin's guilt or innocence.
So even if Chauvin was railroaded, the court trial has at least given
him hope that some appeals court in the future will reverse his
conviction.
peaking, and will have completely peaked by the time of the 2022
elections. The poll results for Joe Biden and Democrat Socialists and
the KKK Democrats have tanked, and unless the Democrats can change
policies completely -- something that nobody I've heard believes
possible -- then the Democrats will be thoroughly defeated next
November.
This once again shows the brilliance of the American Constitutional
form of government, based in checks and balances at the federal level,
in the court system, and in the federal system of states' rights. The
Democrat Socialists and KKK Democrats understand this, which is why
they want to pack the Supreme Court and destroy the American
Consitution system in other ways. But as we're seeing, the American
Constitutional system is winning out and defeating the Democrat
Socialists and KKK Democrats, as will be apparent in November of next
year.
At any rate, there will be no race war, and no new civil war.
Silenced S wrote: Thu Nov 25, 2021 6:44 am > The court system did NOT work properly when Derek Chauvin was
> convicted. The evidence against him was manipulated well before
> the trial even started, and furthermore, our own rogue
> administration directly interfered with the trial by influencing
> the jury into declaring a guilty verdict (this is on top of the
> biased media coverage and threats of violence against the jurors
> which have become the norm).
I take your point, but let's look at this in a different way.
saved).
conviction.
To the contrary, the race war has already peaked, or is very close to
November.
year.
** 28-Nov-2021 World View: South Africa furious at being 'punished' over Omicron variant
The Omicron variant was detected in South Africa, and has already
spread across Europe and to Hong Kong.
Fox News has been replaying clips from Joe Biden in January 2020, just
after Trump had banned travel from China, where Biden decried Trump's
"hysteria, xenophobia, and hysterical xenophobia," instead of
"following the science."
So now Biden has done the same thing, joining the EU and UK in banning
travel from seven southern African countries: South Africa, Namibia,
Zimbabwe, Botswana, Angola, Mozambique, Malawi, Zambia, Lesotho and
Eswatini, giving the appearance of a racist response.
A statement by the South African foreign ministry on Saturday strongly
criticised the travel bans that singled out South Africa because the
variant was already present in multiple countries, but the Africans
had been the first to detect the new variant and announce it.
Director of Health, city of St Louis, where she said the following (my
transcription):
by "hysteria, xenophobia, and hysterical xenophobia," and racism, are
going to become important issues in the following days.
-- Covid: South Africa 'punished' for detecting new Omicron variant
https://www.bbc.com/news/world-59442129
(BBC, 28-Nov-2021)
On al-Jazeera, there was an interview with Dr Mati Hlatshwayo Davis,> "Excellent science should be applauded and not
> punished. [The bans were] akin to punishing South Africa for its
> advanced genomic sequencing and the ability to detect new variants
> quicker. ... These travel bans are based in politics, and not in
> science. It is wrong... Why are we locking away Africa when this
> virus is already on three continents?"
transcription):
This accusation, and the implication that the travel bans were driven> "Travel bans, especially when they are performative in
> this way, target a few countries, whem we know the variant has
> already been isolated, like in the UK, are ineffective. But not
> only that, when done in this way, all they do is perpetuate
> stigma, and xenophobia, against a country in southern Africa that
> did the right thing, that after this variant was isolated, by dr
> sigolewe omoyo, a zimbabwen scientist based in Botswana, that says
> nothing about where this originated. It just means that this is
> just where this superior science was done. The ability to use
> genomic sequencing was done. I mean, this is a country that has
> done exactly what they're supposed to do -- be transparent, use
> their superior science to be able to let the world know what's
> going on.
> And then for South Africa and seven other African countries to be
> targeted with travel bans when other countries that we know of
> right now have the same variant, it's completely unacceptable to
> me. Right? When we talk about global vaccine inequity, we always
> think about this as a supply issue. But mistrust and access are
> equal parts of this. And do we not understand why mistrust does
> not perpetuate when we continue to do things like this? This is
> absolutely unacceptable."
(BBC, 28-Nov-2021)
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 6 guests
