“My answer is this: I am still an optimist because I see what innovation accelerated by artificial intelligence will bring.”
Artificial intelligence won't likely even slow aquifer depletion or many other similar negative trends. During the maintenance phase of this declining civilization he did a lot to slow the decline. But as the new dark age takes hold, it seems his relevance is drawing to a close. One time, he commented that his friend Buffet would not have done well during prehistoric times by shouting at a predator, "I allocate capital well."
This was written 12 years ago and it only seems the negative trends have accelerated.
Higgenbotham wrote: Wed Jun 11, 2014 7:40 pm Bill Gates and others say this is not like Roman times because of all the great technology we have. To that point, let's talk about some of this great technology and how it relates to the drawdown of the resource. I only see technology that works to draw the resource out faster; for example, irrigation in the Midwest that draws down the aquifers, or fracking that draws down the oil resource. Both of these then allow the renewable resource excess extraction rate to be maintained at a higher level than would otherwise be possible. There does not exist any great technology which is putting water back into aquifers or increasing stores of liquid fuels (unless it depletes the other resources - ethanol for example). Most of the enhancement of soil is done with fossil fuel derived products.
Although deforestation has slowed by about an estimated 15% in recent years.
Higgenbotham wrote: Sun Jan 11, 2026 3:18 pm One time, he commented that his friend Buffet would not have done well during prehistoric times by shouting at a predator, "I allocate capital well."
Warren’s success:
- “I was born wired to allocate capital well.” If I was born in Bangladesh and I walked down
the street explaining that “I allocate capital well”, the townspeople would say “get a job”.
- Bill Gates says that if I was born 1000 years ago, I wouldn’t survive because I am not fast or
strong. I would find myself running from a lion screaming “I allocate capital well!!”
https://tilsonfunds.com/BuffettVanderbi ... !%E2%80%9D
Higgenbotham wrote: Fri Jan 09, 2026 3:10 pm At this point, we are close enough to collapse that preparing for collapse seems more important than trying to figure out the when and how.
Yesterday I started my tomatoes indoors.
Last year, I didn't want to spend much money until the garden proved itself out. Turned out I harvested about 200 pounds of tomatoes despite some severe flooding in early July which reduced my crop substantially. How much reduction is hard to say, but maybe half. That was good enough to justify spending some money. We're still using sauce but will probably run out this month. So I invested in a couple grow lights shown in the photo below ($150). Also bought 1,000 seeds of a variety that grew well ($94) and is known to be very disease resistant, which might be necessary if the same ground is used year after year.
However, I'm hoping that an heirloom variety that someone told me worked just as well here will eventually be what I use. He harvested 30 pounds per plant last year. That way I can save the seeds. So I'm trying those at a cost of $8 for about 27 seeds from the same source he used.
As far as the grow lights, I downloaded an app that measures something called ppfd which essentially measures how much light a seedling gets. Winter light supposedly will not give a seedling enough light but I suspect that is not entirely correct. There's a lot of bad information out there and I can be sure my grandmother in rural Nebraska wasn't using grow lights. But I can't ask her because she's been dead for 35 years and is the last one in my lineage who knew how to do this. Hopefully, I can find a very old person around here who knows. I'll also be exploring alternatives to using grow lights such as outdoor cold frames but that's for another day.
As mentioned, I am trying to use as little plastic as possible in the garden. You see the paper milk cartons in the picture below. Problem is, I belatedly discovered that those paper milk cartons are not just paper, they are coated inside and out with a thin layer of polyethylene. So back to the drawing board on that one. I thought they were coated with wax, but that was only true decades ago. I read the wax was discontinued sometime in the 1940s. Also, paper cups and paper plates are coated with polyethylene and those cardboard oatmeal containers have a thin sheet of plastic in them too. I discovered that years ago when I put one of them in a worm bin to decompose it.
I'm willing to go high tech if it pays out but also want to know how to dial it back to dark age tech if need be.
FullMoon
Post by FullMoon »
Knowing when to plant and what you should be growing to have enough food definitely comes with experience. I don't grow tomatoes anymore because they became a fun project that didn't yield their efforts' worth. Roots and greens. Stuff that you can dry and can/pickle. Sure tomatoes work but if you get a bad tummy then it's too much acidity. Also bad for your joints as you age. That's my experience.
Learning to trap, hunt basic animal husbandry will put the meat on your plate. After 10 years of gardening I found that we actually weren't vegetarian and did want/need protein. Some plants provide that but humans in North America are meat eaters. Learn to grow food for your food. And get outside sources as they're available. Pork in Texas is apparently extremely bountiful and needs a little hunting skill. Learning to dry salt and preserve the old fashioned way.
Just checking in.
I bought some calls on GLD about 2 years back that were to expire this friday. Probably my best investment ever. I rolled them over into some that will expire in another 2 years. Still think my hyperiflation logic from howfiatdies.blogspot.com makes sense.
Still have and like Bitcoin but did not do much this last year, though previous year was great.
Have some puts on S&P but have lost money on all my previous ones, so small share of my investments now. Still helps me sleep at night though.
tim
Post by tim »
https://x.com/ModernityNews/status/2011556371045736757
m o d e r n i t y
@ModernityNews
How is this real? How are these people doctors?
From
Eric Daugherty
4:49 PM · Jan 14, 2026
4,397
Views
https://www.zerohedge.com/political/wat ... ely-insane
Dr. Nisha Verma, an OB-GYN tapped by Democrats, evaded direct questions from Republicans, prioritizing “identities” over scientific fact. This exchange highlights how insane woke ideology has infiltrated even medical testimony, undermining protections for women and enabling potential abuse through lax regulations on chemical abortions.
The hearing exposed real risks, like men coercing women into abortions by easily obtaining pills online—no in-person checks required. Yet Verma couldn’t—or wouldn’t—affirm basic truths, leaving observers questioning how such “experts” hold medical licenses in the first place.
https://www.youtube.com/watch?v=ALMRQxE80O0
Adapt frequency.
Its here.
thread: lightswitch
Asked Grok a question about the historical odds of the price of gold getting to 10,000 in a local currency within 2 years of reaching 5,000
and it said 76 out of 76, though this included 56 hyperinflation cases.
https://x.com/i/grok/share/bc28a9f51c79 ... 07f63e7992
Seems like 2 year call options on GLD will probably work.
My song is getting good I think:
https://www.youtube.com/watch?v=56ZwnoEHuYU
Higgenbotham wrote: Thu Jan 08, 2026 3:56 pm Thirty years ago, plus or minus, I thought things like silver and real estate were good ways to build wealth. I was reminded of that during two recent conversations.
The first was with a man around age 65 who is invested in silver. He said that he wished he had picked up on silver being a good buy a long time ago but he wasn't aware of it. I told him that I had been interested in silver in the 1990s but no longer am. Silver recently passed $75, a new record high. I told him that I am now interested in producing my own food and that I feel food shortages are coming long term. He gave me a rather blank look. That was when I realized that even if I had mentioned silver to him back at $5 I would have received the same blank look, as I recognized that same look in people I had talked to about silver back at that time.
It was only within the past hour that I became aware that silver crashed Friday. Last night I noticed bitcoin is sitting on major support at 76K. So bitcoin has gone from about $124K to $76K in several months whereas silver was able to crash from about $124 to $76 in one day.
I would have to think the stock market will be next to crash. There's no historical precedent to say so that I know of (in other words, that a stock market crash typically follows a silver crash), but, then again, there's no precedent for the current "all one market" bubble.
It sure seems like the stock market should crash. There is a slight chance that the money value falls so fast that stocks never crash.
I had Grok read some of my blog on hyperinflation and estimate the chances of getting 5% per month inflation
in the next 5 years and it said 25 to 35% chance. Gemini was 35-45%, Claude 10-20% , ChatGPT 5-10%.
https://x.com/i/grok/share/8a6ed32d0134 ... b3824a8f6d
