Certainly the voltage gradient is near what the literature states as an upper limit. Whether it could be possible to rain electrons in a manner which simulates an actual EMP is questionable.
However, for "TheLastPlainsman" to state "the science is hard" and "it will wipe out every electronic device" is not at all consistent with the same report linked above that many are using as the basis for saying so.
Other parts of the report mention extensive damage to SCADA systems and that's a problem. The report notes the issues with key transformers that I mentioned earlier but has no conclusions. But subsequent studies indicate most key transformers would survive an EMP attack and that is critically important to understanding the effects.
It seems as if many have read the same report I just read and come to conclusions that are not consistent with what the report says.
Nuclear winter
Re: Nuclear winter
Re: Nuclear winter
The following is to correct what I wrote in the past, and to explain
where the assumptions that I was making were wrong, and to summarize
my current understanding.
wrote the above was that the electronic devices would be fried
by some sort of energy from the emp explosion. I didn't see how
it was possible for a single emp explosion to produce enough
energy to fry electronic devices all over the company.
energy would have to come from the emp blast. But the energy required
to fry the electronics would not come from the explosion at all. It
would come the electric power being used by the electronic devices
themselves, when they are running. This also explains why electronic
devices that are turned off would not be affected.
inconvenience a lot of people on an individual basis, but would not
harm the country as a whole.
I was about to say that China today might launch a more powerful emp
explosion, or multiple emp explosions. But wait a minute. The size
of the emp explosion is irrelevant, since the damage is done by
free-falling electrons. Furthermore, if there are multiple attacks,
would the electrons from multiple attacks do more damage than the
electrons from one attack? It would seem by the Law of Diminishing
Returns that subsequent attacks would be far less marginally effective
than the first one.
OK, so the incorrect assumption that I was making when IJohn wrote: > Unless someone has figured out how to violate the laws of
> thermodynamics and conservation of energy, the effective strength
> of an emp attack must vary invesely with the square of the
> distance as well. The only way that this could be violated is if
> the emp attack is targeted -- that is, if the attack is a vector
> targeting a single city. But if the emp attack is supposed to
> attack the entire country from California to Washington to Maine
> to Florida, then all of the energy from the emt explosion would
> have to be spread over the entire 3.5 million square miles. So if
> the strength of the emp explosion is X, then the strength of the
> attack per square mile is X/3.5 million.
John wrote: > OK, so I guess that explains it. An emp blast over North Dakota
> would result in the E1 electrons being sprayed over the entire
> country, from California to Maine, and fry all the
> electronics.
It takes energy to fry an electronic circuit, and I assumed that theHiggenbotham wrote: > Electrons generated close to the earth's surface and hitting
> nearly all at once at nearly the speed of light is about as bad as
> it gets, as far as a mechanism goes for frying electronics. Beyond
> that, that mechanism is way too complicated for somebody like me
> to have a clue as to how to quantify it in order to know whether
> thresholds would likely be exceeded.
This would seem to imply that an emp attack could harm orCommission to assess threat to US from EMP attack wrote: > Automobiles were subjected to EMP environments under both engine
> turned off and engine turned on conditions. No effects were
> subsequently observed in those automobiles that were not turned on
> during EMP exposure. The most serious effect observed on running
> automobiles was that the motors in three cars stopped at field
> strengths of approximately 30 kV/m or above. In an actual EMP
> exposure, these vehicles would glide to a stop and require the
> driver to restart them. Electronics in the dashboard of one
> automobile were damaged and required repair. Other effects were
> relatively minor. Twenty-five automobiles exhibited malfunctions
> that could be considered only a nuisance (e.g., blinking dashboard
> lights) and did not require driver intervention to correct. Eight
> of the 37 cars tested did not exhibit any anomalous response.
> http://www.empcommission.org/docs/A2473 ... on-7MB.pdf
than the first one.
Re: Nuclear winter
From Wikipedia:
https://en.wikipedia.org/wiki/Nuclear_e ... etic_pulseThe EMP at a fixed distance from an explosion increases at most as the square root of the yield (see the illustration to the right). This means that although a 10 kiloton weapon has only 0.7% of the energy release of the 1.44-megaton Starfish Prime test, the EMP will be at least 8% as powerful. Since the E1 component of nuclear EMP depends on the prompt gamma ray output, which was only 0.1% of yield in Starfish Prime but can be 0.5% of yield in low yield pure nuclear fission weapons, a 10 kiloton bomb can easily be 5 x 8% = 40% as powerful as the 1.44 megaton Starfish Prime at producing EMP.
Re: Nuclear winter
I would lose my Mac. I keep it running 24/7 on several BOINC distributed computing programs.
