John wrote: Sat Nov 13, 2021 10:28 pm This has led to new rounds of hysteria, as some people are claiming
that we're returning to the hyperinflation of the 1970s, something
that I've said many times is impossible, based on the level of debt.
Few people would count the 1970s inflation as "hyperinflation", just "high inflation".
High levels of government debt and deficits is the cause of out of control inflation. They get to where they have to print.
The US seems to have reached the levels that usually result in hyperinflation.
The only time the US government debt was close to the current levels was after WWII but after the war they were able to drastically cut the military spending so there was no deficit. Today they could not do any such drastic cuts in spending. It seems to need both high debt and high deficit to get out of control.
If the CPI did not use the bogus "owner's equivalent rent", just real rents and house prices like in the 1970s, our current CPI would be over 8%.
John wrote: Sat Nov 13, 2021 10:28 pm So there's every reason to believe that the CPI will fall sharply in
2022, and there's no reason to believe that the CPI increases will
continue as they did in the 1970s.
There was a huge amount of money creation in the last few years but the velocity of money got so low that we did not get inflation.
Now all it takes is for the velocity of money to go up and we can get inflation.
With higher inflation levels, the velocity of money goes up.
With inflation much higher than bond interest, people may sell bonds that the Fed may end up buying with new money.
It is not for sure yet, but there is some reason to worry.
Do you think if we get a CPI to 8% or 9% that the market will crash?
I really believe the next CPI will be higher than the 6.2% we just got and keep going up in coming months.
I will keep watching with interest.
The Peter Schiff video I just posted in my topic also points out that the CPI uses "substitution" (people buying chicken instead of steak, for example) and improving technology (1 gigaflop PC instead of 100 megaflop PC) in ways that lower inflation, starting in the late Nineties. In other words, our standard of living is dropping, so inflation is lower, but our standard of living is rising, so our inflation is lower.
And I would love to be one of those polled for my "owner's equivalent rent". "My two bedroom apartment style condo? Yeah, I would rent that out for $10,000 a month. $120,000 a year." I would single handedly add a tenth of a percent to the CPI!
The White House regime managed by Ron Klain, the zionist whose hands are holding the Biden puppet, are actively involved in crafting the narrative to designate White parents resistant to mandates & CRT as domestic terrorists at the behest of the NSBA.
I’m not going to say this is unprecedented, but this is a clear example of a top down war on Americans being waged by the American government.
This government is illegitimate and it needs to be called out at every turn that it is not only illegitimate, it is captured, and it is prudent to point out who captured it. fify
https://www.investmentwatchblog.com/its ... errorists/
Rule 5
Sidetrack opponents with name calling and ridicule. This is also known as the primary ‘attack the messenger’ ploy, though other methods qualify as variants of that approach. Associate opponents with unpopular titles such as ‘kooks’, ‘right-wing’, ‘liberal’, ‘left-wing’, ‘terrorists’, ‘conspiracy buffs’, ‘radicals’, ‘militia’, ‘racists’, ‘religious fanatics’, ‘sexual deviates’, and so forth. This makes others shrink from support out of fear of gaining the same label, and you avoid dealing with issues.
Rule 9
Play Dumb. No matter what evidence or logical argument is offered, avoid discussing issues except with denials they have any credibility, make any sense, provide any proof, contain or make a point, have logic, or support a conclusion. Mix well for maximum effect.
Rule 18
Emotionalize, Antagonize, and Goad Opponents. If you can’t do anything else, chide and taunt your opponents and draw them into emotional responses which will tend to make them look foolish and overly motivated, and generally render their material somewhat less coherent.
Not only will you avoid discussing the issues in the first instance, but even if their emotional response addresses the issue,
you can further avoid the issues by then focusing on how ‘sensitive they are to criticism.
Revised April 2000 – formerly SEVEN Traits)
1) Avoidance. They never actually discuss issues head-on or provide constructive input, generally avoiding citation of references or credentials. Rather, they merely imply this, that, and the other. Virtually everything about their presentation implies their authority and expert knowledge in the matter without any further justification for credibility.
2) Selectivity. They tend to pick and choose opponents carefully, either applying the hit-and-run approach against mere commentators supportive of opponents, or focusing heavier attacks on key opponents who are known to directly address issues. Should a commentatorbecome argumentative with any success, the focus will shift to include the commentator as well.
https://www.zerohedge.com/political/why ... m-religion
Mental filth so avoid it. Plant your food and avoid the brain dead. Brandon is a mindless fool.
2019 foreign aid.
Israel ($3.3 billion)
Jordan ($1.52 billion)
Egypt ($1.43 billion)
Tanzania ($547 million)
Kenya ($544 million)
Uganda ($533 million)
Mozambique ($522 million)
South Africa ($482 million)
Zambia ($457 million)
Iraq ($454 million)
2021 Taliban (85-Billion)
Pay your taxes biscuit eaters.
Fauci Injecting Ebola Into Monkeys
Fauci Ebola virus research gets millions of dollars of NIH funding
Fauci New Ebola research exploring how Ebola spreads in people with implication for targeted Ebola viral treatments
Olena Shtanko, Ph.D., at Texas Biomedical Research Institute has received funding from Dr. Fauci and the National Institutes of Health (NIH) to explore different aspects of Ebola virus infection
“The general model of spread of Ebola virus infection where a viral particle infects a cell, replication begins, new virus particles are made and released into the body to infect neighboring cells is probably a bit too simplistic,” said Shtanko, who is part of the Texas Biomed Host-Pathogen Interactions Program. “How does the virus really get from the site of initial infection, penetrate dense tissues, evade the body’s defense system and end up in distant organs, such as the liver, just a few days later? We really don’t know.”
Over the next two years, Shtanko will explore precisely how the Ebola virus hijacks a key immune cell in the body called macrophages. Even though these large cells specialize in detecting and killing harmful invaders, Ebola and other filoviruses have found a way to enter and hide in the cells. The macrophages then help distribute the virus around the body, serving like Trojan horses, through an unknown mechanism. Shtanko will investigate how exactly virus infection transforms migration and invasive properties of macrophages to maximize its spread in the host.
Dr. Shtanko is excited to explore a possible alternative mode of Ebola spread — tunneling nanotubes, dynamic connections between cells, which allow cells to communicate by exchanging content over relatively long distances (up to 200 microns). While these structures have been shown to play a prominent role in promoting neurodegenerative diseases, cancer, and spread of a variety of viruses, including HIV-1 and influenza, no one is known to have investigated their role in disseminating Ebola and related viruses.
“It is critical to understand if Ebola virus is able to crawl from cell to cell without ever creating new virus particles that move freely in the body, because those free particles are the typical targets for the immune system and pharmaceutical interventions,” Shtanko said. “Ebola virus might be escaping early detection and perhaps eventually establishing persistent infection by using these nanotubes.”
Such basic research insights can help inform development of more effective anti-viral treatments or vaccines. The research projects will involve cells and tissues infected with Ebola virus – research that can only be safely conducted in the highest level biocontainment laboratories, called BSL4. Texas Biomed is uniquely positioned for this type of research, hosting both a BSL4 lab and the Southwest National Primate Research Center. While this Ebola research will be in vitro (or in a petri dish), the studies will eventually move to more advanced animal models.
Dr. Shtanko is collaborating with several Ebola experts Texas Biomed President/CEO Larry Schlesinger, M.D., a renowned expert on macrophages whose lab studies macrophages and their role in tuberculosis; Professor Andrew Hayhurst, Ph.D., who has engineered novel llama domain antibodies specific for Ebola virus; and Professor Ricardo Carrion, Jr., Ph.D., an expert on development of non-human primate models of Ebola virus disease.
This research is funded by your tax dollars grants #AI151717 and #AI154336 from National Institutes of Health
https://nationalinterest.org/blog/reboo ... eal-173764
Israel Aerospace Industries (IAI), the country's top aerospace and aviation manufacturer, has developed the Scorpius family of systems that scans a sphere of the operating environment for targets and deploys a narrowly focused beam to interfere with multiple threats across the electromagnetic spectrum. The high-tech weapon is categorized under "soft protection" because it doesn't cause physical harm. Instead, it disrupts the operation of electromagnetic systems, such as radar, electronic sensors, navigation, and data communications.
The infected monkeys will show in His time in the valley of decision.
https://newspunch.com/us-army-surgeon-t ... -injuries/
You are ruled by evil filth and ruthless money pricks pure and simple.
Smart people stopped going to Universities. They know it about slaves going into massive debt to fund filthy Marxists.
Ursinus College in Pennsylvania, all students and faculty are vaxed they are having a outbreak right now,
kids in the dorms are being sent home.
The most vaccinated American state (71% fully vaccinated) smashes highs for cases.
In our case it was defined as other since the retard meter is pegged to 11.
The misery inflicted was man made as the slack jawed lunatics march.
The data fragily has overwelmed the lie cheat steal with burn loot murder crayon chewers anyways.
One last push in 2021 for the paper cults to unload on the true idiots.
These murder cults will only be happy with daily jabborites sheep.
One or two years more education you can join the brain dead cults of the left and right.
Read actual economics as they held a mirror to match themselves you damned fools.
Father Martin was corrent on your actaul condition and the piggyback cults Human Action.
The only feed back is level 5 shit posters slaves in debt up there eyeballs on their knees.
About kow plant treefoil and plant.
We told you we will trade above the margin only in fair trade.
This was and is true as the paper filth lie cheat and steal with burn loot murder decieve you.
By this next fall even decieved retards will not deny and curse the light as they have.
They will wear out the Saints. Hold the line you gentle souls.
thread: 49xx, amos, anderson
https://cdn.substack.com/image/fetch/f_ ... 0x203.jpeg
https://twitter.com/i/status/1459080422365663232
Cobain
"Fear the stupid; they're contagious."
Five Laws
Law 1: Always and inevitably everyone underestimates the number of stupid individuals in circulation.
Law 2: The probability that a certain person be stupid is independent of any other characteristic of that person.
Law 3. A stupid person is a person who causes losses to another person or to a group of persons while himself deriving no gain and even possibly incurring losses.
Law 4: Non-stupid people always underestimate the damaging power of stupid individuals. In particular non-stupid people constantly forget that at all times and places and under any circumstances to deal and/or associate with stupid people always turns out to be a costly mistake.
Law 5: A stupid person is the most dangerous type of person.
2 by 2 matrix.
Mark Twain: Never argue with stupid People, they will drag you down to their level and then beat you with experience.
Ponerology - The Science of Evil
https://www.youtube.com/channel/UCRIQM- ... VPv980YZsw
Be Prepared to Go Hungry as a Prolonged Food Shortage is Coming 80,883 views
Nov 5, 2021
thread: 100 day
https://www.zerohedge.com/markets/used- ... ere-strike
Since the 40k local bankruptcy implosion we linked real time the 75 HP to 150 HP tractors vanished as we linked the auctioned facts then.
You are not prepared and what do you know as they attack the actual producers who trade above the margin.
Two weeks ago they attacked a guy who said no we will not sell even one non chipped tractor to the brain dead.
We will not round out block heads or lie cheat steal failed in life try hell village and useful idiots who
only know the grocery store is where food comes from. Talking to crayon chewers who graduated to paste eaters
in active measures. Old enough to care and young enough know better is attacked non stop.
botport https://www.youtube.com/watch?v=-aVBn2--TWM transitory cost
Sat Nov 18, 2017 10:27 pm This video is no longer available because the YouTube account associated with this video has been terminated.
Of course they murdered the truth of the account.
404 the real facts is all they are. Lie cheat steal burn loot murder filth covers the land.
As warned - I will treat you with contempt and cover you with filth. People will stare at you in horror. GOD'S WORD
The vast majority of farmers are family farmers who haven't bought a new piece of major equipment in decades who are struggling like they always do to make ends meet.
This year may be different because grain prices are higher, they have hardly skyrocketed,
but whatever profits there may be are going to go to pay old debts.
You really should refrain from posting if you have no idea what you're talking about. tyler
There is not actual inflation yet. This is all fear induced stupidity resulting in corporate greed by knowing they can price gouge not unlike gas stations during every hurricane and the actual sick traitors in government who will do nothing about it. Idiots slaves mired in stupidity.
https://store.mises.org/Human-Action-Th ... 10522.aspx
It was (and remains) the most comprehensive, systematic, forthright, and powerful defense of the economics of liberty ever written.
This is the Scholar's Edition: accept no substitute.
https://www.youtube.com/watch?v=V_87AoQaKNw
California has shelled out at least $20 billion in fraudulent unemployment benefits since the beginning of the pandemic, 11 percent of all benefits paid in the Golden State.
That is more than the 2021 budgets of Delaware, Maine and Montana combined.
Rope would fix this.
On the whole, the pandemic may be ending, but the economic aftermath of the pandemic has only just begun... JR
Only about one-third of that money goes toward actual infrastructure such as bridges, tunnels, roads and airports.
The rest is for vague causes like “human infrastructure,” which includes training, oversight and other government intrusion.
https://www.youtube.com/watch?v=brLNe4UTmgM
Show up in a skirt with balls your not going to get paid skippy.
Next.
Article examines possible explanations for “winner-loser reversals” in the national stock market indices of 16 countries.
The apparent anomaly of winner-loser reversals in national market indices therefore remains unresolved.
