https://www.zerohedge.com/geopolitical/ ... fundraiser
That’s something plenty of pundits would have been able to articulate as little as 25 years ago. They would have known they should be looking for it; they would have recognized the signs in readily available media reports. To point it out as a plausible explanation – an obvious act of ordinary housekeeping in global security management – wouldn’t have been considered special pleading. It would have been considered sanity.
https://www.thegatewaypundit.com/2019/0 ... ite-house/
https://www.latimes.com/archives/la-xpm ... story.html
The Europeans insist that the consortium must have the right “forever” to continue subsidizing Airbus to make sure it survives.
Yes, Wall Street and the Bolshevik Revolution by Anthony Sutton covered this.
Jacob Schiff gave Bronstein money that murdered million of Christians of Israel Mosche Blank lineage.
https://holodomorinfo.com/tag/jacob-schiff/
The village and useful idiots only have the color card.
Didn't this guy realize he was dealing with a tribe member?
https://www.zerohedge.com/political/dea ... dam-schiff
thread notes:
Trotsky in New York and Lenin in Switzerland also seemed to have protection/finance. Antony Sutton explored this at length.
http://www.antonysutton.com/
As do Docherty and Macgregor today.
https://www.youtube.com/watch?v=3naToXWe1JU waxmans seat to evil and eternally compromised
Hes is going to probably should hang unless the remaining democrats can save themselves from this sickness and darkness taking them over.
Last weeks descend function of regression as the center forges ahead.
The 13th and final rule for radicals is “Pick the target, freeze it, personalize it, and polarize it. Cut off the support network and isolate the target from sympathy. Go after people and not institutions; people hurt faster than institutions.” Mon Jun 04, 2018 8:06 am
Higgenbotham wrote:From 2012.
Flutter is a self-feeding and potentially destructive vibration where aerodynamic forces on an object couple with a structure's natural mode of vibration to produce rapid periodic motion. Flutter can occur in any object within a strong fluid flow, under the conditions that a positive feedback occurs between the structure's natural vibration and the aerodynamic forces. That is, the vibrational movement of the object increases an aerodynamic load, which in turn drives the object to move further. If the energy input by the aerodynamic excitation in a cycle is larger than that dissipated by the damping in the system, the amplitude of vibration will increase, resulting in self-exciting oscillation. The amplitude can thus build up and is only limited when the energy dissipated by aerodynamic and mechanical damping matches the energy input, which can result in large amplitude vibration and potentially lead to rapid failure. Because of this, structures exposed to aerodynamic forces — including wings and aerofoils, but also chimneys and bridges — are designed carefully within known parameters to avoid flutter. In complex structures where both the aerodynamics and the mechanical properties of the structure are not fully understood, flutter can only be discounted through detailed testing. Even changing the mass distribution of an aircraft or the stiffness of one component can induce flutter in an apparently unrelated aerodynamic component. At its mildest this can appear as a "buzz" in the aircraft structure, but at its most violent it can develop uncontrollably with great speed and cause serious damage to or lead to the destruction of the aircraft,[1] as in Braniff Flight 542.
In some cases, automatic control systems have been demonstrated to help prevent or limit flutter-related structural vibration.[citation needed]
Flutter can also occur on structures other than aircraft. One famous example of flutter phenomena is the collapse of the original Tacoma Narrows Bridge. Another is a particular playground swing in Firmat which "swings itself" with such force that it leads many to believe it is haunted.
http://en.wikipedia.org/wiki/Aeroelasticity#Flutter
a growing commitment to steady inflation = aerodynamic forces on an object
failure of soft central planning = result in large amplitude vibration and potentially lead to rapid failure
how do you like being a guinea pig = in complex structures where both the aerodynamics and the mechanical properties of the structure are not fully understood, flutter can only be discounted through detailed testing
The stock market, in addition to the 3 megaphone patterns discussed a few months ago is, since then, "fluttering" between 2820 and 2940 on the S&P. According to my analysis, this could "potentially lead to rapid failure".
Higgenbotham wrote:This is a good link to get a long term perspective (5 years) on the rapid flutter currently taking place in the S&P:
http://bigcharts.marketwatch.com/advcha ... e&state=11
** 03-Oct-2019 World View: Gloomy October
After the Dow Jones Industrial Average has sold off 800+ points in the
last two days, stock futures have gone negative in the last hour, this
morning (Thursday).
Major market crashes in the past have occurred during the month of
October, and there is speculation that this will be another such
October. It's worth pointing out that the same speculation occurs
almost every October, and the speculation fizzles by mid-October.
This year, such speculation refers to the global economic slowing,
with China and Germany leading the way. In addition, there's no end
in sight for US-China trade disputes, or for Japan-South Korea trade
disputes. For China, there's no end in sight to the Hong Kong riots.
These factors are causing many companies to move their supply chains
out of China and into other countries like Vietnam, and to move their
money out of Hong Kong into Singapore. Such actions may be beneficial
in the long run, but in the short run they're adding to concerns that
this will be a gloomy October.
---- Sources:
** Why Does the Stock Market Go Lower in October?
** https://finance.zacks.com/stock-market- ... -6428.html
** Stocks just delivered a reminder about October’s reputation for
volatility
** https://www.marketwatch.com/story/histo ... 2019-10-01
https://drive.google.com/file/d/0B0pBgJ ... JFcm8/view
Review.
The bargaining process of the alleged moderate democrats assumes they can control the narrative.
No it will not wash off. Independents will not pick up a fire hose to wash the filth off the death cult democrats
trying to run to the middle. The Republicans brand is damaged also.
As the saying goes I only went up to my ankles. Yes head first was a bad idea as the mitt bots try to pull up into view.
No one was happy with the wiki facts.
Snowdon should be allowed home after his 10 year exile for both party's to humble themselves.
Assange should be left alone and set free.
The corporate democrats are evil intent and yes we understand security swot analysis of evil.
We covered dragonfly.
As Asia stabilizes and come to their collective senses and the EU walks in descending circles the market capital influx will stabilize as the sweep accounts are being dealt with. Then all Hell will break loose going into final edge of the judgement window. No soul is lost as it chooses to be
sealed and then simply is.
The Sogo groups had enough time to prepare for this segment. Have you?
Dow still holding the July 16 high...
Higgenbotham wrote:We STILL don't know whether Higgenbotham's Magic Sauce pinpointed the top of the stock market. The DOW Jones Industrial Average DID top on July 16 and that top is holding so far...
Higgenbotham wrote:10/10/2002 - 03/06/2009 = 2339
2339*1.618 = 3784
03/06/2009 + 3784 = 07/16/2019 = lunar eclipse
Higgenbotham wrote: > Dow still holding the July 16 high...
So where are you these days? Are you in the market?
Yes, I'm still in the market and still positioned for a crash.
Tinypic has shut down, so I haven't been posting any charts or results.
Users browsing this forum: aedens, Bing [Bot] and 2 guests
