https://www.newyorker.com/news/news-des ... -mans-land
https://www.zerohedge.com/news/2019-07- ... ss-country
Send them home and AOC with the ALCU idiots to the other site.
I'm already beating bots rated 100 points higher after only another week of practice.
Higgenbotham wrote:This is my progress in playing the komodo chess bots in blitz chess over the past 2 months. In blitz, the player has 10 minutes to play an entire game against the bot. If you run out of time, you lose, even if you had the advantage prior to running out of time. I had never played blitz or any competitive chess prior to this.
I fully short the S&P futures again tonight. No idea if this is the top but this is my best umpteenth guess.
Also, at these levels, there's no way I will do any more bot smashing, which is in direct conflict with what I said just a week or two ago. After looking at the long term chart after this recent runup, I decided to sell and hold.
** 03-Jul-2019 Chess bots
playing. It sounds like you're in that same place.
By the way, my highest tournament rating was 1780.
I've had my periods of addiction to chess, where I couldn't stopHiggenbotham wrote: > I'm already beating bots rated 100 points higher after only
> this.
That's excellent. I honestly don't ever hope to get my Blitz rating that high. But it's been an interesting experience. I've played 1164 Blitz games since signing up on April 13, which amounts to about an hour a day on average, but varies quite a bitJohn wrote: I've had my periods of addiction to chess, where I couldn't stop
Years ago, I had a roommate who graduated from MIT and was a chess master. I didn't find that out until we played a game of chess. About halfway through the game, I looked up at him and asked if he was a rated player. He said yes. I asked, what's your rating? I believe he said 2275. That was the end of our chess playing. Later, he played me blindfolded and won.
I just moved up to komodo7 rated 1491 and beat that one on my first attempt, which gave me 13 rating points.
Looking at this long term weekly chart of the nearby S&P futures together with other information (some of which has been previously posted here), I think the market is in the zone for a high. Since early 2018, it does have the appearance of the flutter effect discussed years ago.
Megaphone pattern, in other words.Flutter is a self-feeding and potentially destructive vibration where aerodynamic forces on an object couple with a structure's natural mode of vibration to produce rapid periodic motion. Flutter can occur in any object within a strong fluid flow, under the conditions that a positive feedback occurs between the structure's natural vibration and the aerodynamic forces. That is, the vibrational movement of the object increases an aerodynamic load, which in turn drives the object to move further. If the energy input by the aerodynamic excitation in a cycle is larger than that dissipated by the damping in the system, the amplitude of vibration will increase, resulting in self-exciting oscillation. The amplitude can thus build up and is only limited when the energy dissipated by aerodynamic and mechanical damping matches the energy input, which can result in large amplitude vibration and potentially lead to rapid failure.
I beat a bot rated 1628 on the fifth attempt.
Your pushing on a critical string H
The bund to the bond is no damn accident as we have shown since the white flags got flushed out. Yes of course it will be shown as defense metrics for the sheep. Zones to note are oil, gold, with Dr. Copper as a inflection and now a simple invasion zone looming for control since the market in the CAR finds itself as the current flare for soon to be massive slaughter they even gloat over. The head winds are known and the sheep are grazing only. As we mentioned sheep have high pain tolerance to mask the pain as the wolves will target another in the flock in geopolitical norms well seen here on flows.
Deflation of the basket currency's is not a sign but separation of the times only as they scale the wall in terminal velocity.
The Beasts will do anything it wishes seen in the periphery was just a means to and ends.
Be a Mountain goat since the sheep are being rounded and roughed up for slaughter as we have seen.
Moat investing is based on a simple concept just as the Sogo groups so. The fed carry means the rates will drop if they see the EU improving. I do not see that since the AI augmentation has honed the productions to eliminate what ever they want. As we noted the lines have inspectors at the end and AI automation in between. The complaint in the States will be the usual suspects as AI implementations projects complete and the obvious effect in reverse of flows as issues of Operation 936 back then on the "actual labor" issues. The problem is and will be the useful and cheerful idiots littered along the way as the frogs. http://gdxforum.com/forum/search.php?ke ... sf=msgonly
As we know, Sogo Shosha groups are sufficiently diversified to withstand periodic downturns in certain sectors of the economy.
Even still, the market share of the Sogo Shosha has declined because numerous manufacturers in a variety of industries have opened up plants in countries with weaker currencies and because Japanese companies have started to manage their own international white flag trade.
This we noted clearly in the Forums on the signal that we confirmed. This will mirror back as supply chain realities.
As I mentioned when the river lowers the turbulence is seen and modified to flow efficiencies to supply.
Sticky wages was operation 936 for local issues and packaged as Nafta for the true believers.
Sometimes more alike than we wish to convey since the groups must endure the missing value stream.
As we seen they are since the next rendition has already been here way over a year.
As we have seen the AI itself was shut down since the developers could not understand it.
It was internalized only.
What these farmers and herdsman's do not understand they are next to be decimated as control groups are eliminated also.
They had no issue taking out ours to continue the debauchery now in another zone since moderates understand the game
as well as they do. The veil was played by both sides and we know that.
https://www.zerohedge.com/news/2019-07- ... posit-rate
thread: Critical Theory
Marx's theoretical formulation of the relationship between economic base and ideological superstructure focus on how power and domination operate in Marx's footsteps, Hungarian György Lukács and Italian Antonio Gramsci.
https://uww.academia.edu/StanislavVysotsky
Since the tables were turned you see what was told as it would be.
Avoid walking in circles since we know what they will do again to us. As it was very clear try to see if they will leave you alone.
We know who and what tower they coveted and how many for its price. As we see in the CAR region it is the same expense to be poured upon us again. The solution will not be appreciated since before our Pastor was spared from the two who sat above, as the executioners witnessed being seated above. In fear they allowed them to leave before dawn.
God as my witness I do not know what will happen to this village marked for death.
They know who they are.
The most radical change is that before his NDE he was a cold hearted atheist professor,
https://www.youtube.com/watch?v=tfy_R_OB7G4
