I would defer to the Demark recycle sequence in this case.aeden wrote:log three get out h
True low/True high – is the lowest and the highest point for a setup,
BUT including gaps before bar 1 and the days after the 9-th bar, qualifying for a setup bar.
No sooner than I posted that it flipped hard one minute negative three minutes later on the potential sequence completion. Unchanged is being tested now.aeden wrote:I will check peer numbers also on that note H
https://www.zerohedge.com/sites/default ... k=AVL07V-b
Tweek week as the girls of summer show that thang.
Small Caps Turn the Tables on Large Caps, With Russell 2000 Index Outdistancing Russell 1000 Index.
https://us.spindices.com/documents/addi ... recard.pdf
“this time is different”
The quality of the bubbles across time can be considered by looking at the leading bubble stocks in 1929, 1972 (Nifty Fifty), 2000, and 2018 (FAANG, etc.). It can be seen that not only have the bubbles gotten bigger and more ridiculous, the stocks leading the bubbles seem junkier. To think that Netflix and Tesla are leading bubble stocks seems like kind of a joke to me in comparison to companies like RCA (1929) and Cisco (2000). This bubble seems like some combination of the 1920s bubble and the South Sea Bubble.
https://www.youtube.com/watch?v=7Ybu4fzL-dU <.8 regression but beta is no buffer
Sometimes the actions people take have the opposite of their intended effect.During (Elon) Musk's childhood, he was an avid reader. His childhood reading included Isaac Asimov's Foundation series from which he drew the lesson that "you should try to take the set of actions that are likely to prolong civilization, minimize the probability of a dark age and reduce the length of a dark age if there is one."
I agree as this week end as I will stack python after fishing with grand kids.
The world never understood the lesson since half the world cannot read.
This implementation uses `phi` as a precision parameter equal to
`a + b` from the Beta parameters.
def __init__(self, endog, exog, Z=None, link=Logit(),
link_phi=sm.families.links.Log(), **kwds):
Parameters
endog : array-like
1d array of endogenous values (i.e. responses, outcomes,
dependent variables, or 'Y' values).
exog : array-like
2d array of exogeneous values (i.e. covariates, predictors,
independent variables, regressors, or 'X' values). A nobs x k
array where `nobs` is the number of observations and `k` is
the number of regressors. An intercept is not included by
default and should be added by the user. See
`statsmodels.tools.add_constant`.
Parameters
endog : array-like
exog : array-like
https://www.scribd.com/doc/282757414/Ch ... -ExplainedHiggenbotham wrote:Sometimes the actions people take have the opposite of their intended effect.During (Elon) Musk's childhood, he was an avid reader. His childhood reading included Isaac Asimov's Foundation series from which he drew the lesson that "you should try to take the set of actions that are likely to prolong civilization, minimize the probability of a dark age and reduce the length of a dark age if there is one."
They could not listen then and will not now. The actual study's have been done but insults and attacks on logic never stopped them before either.
https://songhuiming.github.io/pages/201 ... -examples/
Special blend of greed, hubris, incompetence and bad luck to make this mess.
The current ruling was the last round to the middle classes as a head shot the scotus just did.
