Higgenbotham wrote:It's my conclusion that the above-referenced RQ Test is flawed.
The reason for saying that is most of the questions are not such that it is reasonable to gauge distinct levels of uncertainty for most people.
For example, "The population of Beijing was over 20 million in 2008." The population was in fact 17 million. The only reasonable answer for a non-expert is "I don't know." All the non-expert really knows is right around 20 million seems reasonable. Slightly under or slightly over is a coin toss. Any guess a non-expert makes in the "I don't know" range provides no useful information.
I think the gist of the test is to tabulate the degree to which a person is more uncertain about what they get wrong versus what they get right and score higher for a higher degree of that. That's difficult to do given the subject matter of the test.
I took the test again, and gamed it by looking up some of the answers and being very sure of those, and not so sure of the rest. Doing that only improved my score from 81 to 83, so there must be something more to it that I don't understand.
Higgenbotham wrote: My result for the Basic RQ Test:
Your RQ Score is 81!
Such a score is high. Risk intelligence can be measured by calculating something called a "calibration curve".
Your K factor is 35. This is high. This means that your RQ score in this test is a quite reliable measure of your risk intelligence.
Also, I found a poker player's forum and two of those players who took the test scored 84 and 88. I had wondered how high is high, and that's the best answer I can come up with. The test site doesn't mention anything about the dispersion of the test results.
test results
https://www.seattletimes.com/opinion/af ... g-seattle/
The dead rings are growing and yes liberals are a mental disorder.
https://www.zerohedge.com/news/2018-04- ... closures-0
Nobody gave a second thought when they simply walked and demanded $25,000 for fees.
Painful yes. Lesson is clear and simple. Evolve under your terms. You will fail into something better.
Waited for the moment the city put it on paper and flipped the closed sign.
As conveyed we left and it took a decade later for the state police and audits to prove they
were thieves.
I never ignored the gann window as the convulsion windows shows up in a larger macro scale.
As we know they will and are taking anything not nailed down and have.
The summer meetings will only confirm the points we already see.
I was happy to see the Office stopped by to have a meeting and Sara has our regional
thoughts since the liberals prove what we already knew.
Futures are down since as we know for every one who sees twenty five are leaving as Dietrich Bonhoeffer knew
what was coming since cheap faith indeed has a cost. The what is wrong with you generation will pay a steeper price
than they can fathom.
The trends provide some lessons also.
https://www.greedandfear.eu/trading/mar ... redictions
The direct method is a method of creating the cash flow statement in which actual cash flow information from the
company's operations segment is used, instead of accrual accounting values.
Direction of cash flow.
Thread: 2018
Category: Market psychology
Ultra Pure Water (UPW), water that is thousands of times purer than drinking water.
Water is regarded as an industrial solvent.
A typical semiconductor manufacturing facility uses two to four million gallons of ultra-pure water per day.
One of these days they will figure it out we are more pragmatic as what they are taking from you is something you
cannot replace and you are stuck with to control 187 hazardous air pollutants in transfer costs of solvent based tech sectors.
Base erosion and profit shifting (BEPS) refers to tax avoidance strategies that exploit gaps and mismatches in tax rules to
artificially shift profits to low or no-tax locations.
Under the inclusive framework, over 100 countries and jurisdictions are collaborating to implement the BEPS measures and tackle BEPS.
Being pragmatic means even the Chinese interpret the OECD socialist suicide march of cost sink.
The new supply chains are being built since bureaucracy delays embraced semiconductor lines that were
outdated before they were even shipped.
In time as before the to busy to pay attention will consider the socialist on suicide watch and Marxist plain sight order of operation murder.
The new value streams means operational levels that do not injure the vulnerable.
The report identified 6,000 automated bots which had the same characteristics.
They all had alpha numeric 15 character.
Patterns are real and the medium range targets still turns on the flat screens.
https://www.youtube.com/watch?v=4z3gkq_gWL4
Morgue is more of a bear than we are H.
The drift will be epic into summer as the dxy bears
try to step over Bernacks ghost. We will just have to wait and see.
Andropov's ghost tells the tale who opened the gate point blank.
Anyways,
https://www.zerohedge.com/sites/default ... k=M6G4z21g trends back to Wed Mar 28, 2018 8:48 am notes
Also as we discussed.
I lasted ten minutes in the meeting and excused myself. The others asked later if a mason jar was a solution.
You know at times you cannot even take the time to explain risk to some. I reminded them eighty percent of you lost 40 percent in aggregate and you never seen it coming. Already the tone has changed on why they consider no change in attitude a viable plan going forward. Simply amazing how some are entrenched as the generational dynamics are with boomers and the vapid nihilism of "relativism" as John conveyed as intractable dynamics.
http://www.novinite.com/articles/189794 ... ern+Europe
We will see soon what developed and undeveloped ensue. Interesting themantics of corridors.
I would assume Iran would be smart enough to not pull the wolf's tail, again.
Then again we have more advanced timelines of decay also in realities ignored.
The US government controls the borders or it has no legitimacy.
Andropov was correct on his assertions. Americans are to dumb to fathom it.
https://www.inese-vaidere.lv/wp-content ... mm_web.pdf
https://archive.org/stream/TheSwordAndT ... B_djvu.txt
In the first year 26 died from being immolated from accidents.
Carelessness the destroyer of Worlds.
https://www.zerohedge.com/news/2018-05- ... -nightmare
Didactic. Instructive; educational; fitted or intended to teach.
http://oll.libertyfund.org/pages/mises- ... a-glossary
https://translate.googleusercontent.com ... g4bXQlk-vg
https://translate.googleusercontent.com ... Gfllo4HQOA
https://en.wikipedia.org/wiki/2018_Hajj ... _airstrike
Another note is can easter island number two muster enough backbone to clean up the House of Commons.
Anyways on another view as bb notes
http://gdxforum.com/forum/viewtopic.php ... 405#p39395
Someone else also connected the dots between Skripal, Leonard Rink, GRU and Syria: an interview with Boris Volodarsky, an author and historian of Soviet and Russian defectors to the West who is too close to British intelligence to be regarded as impartial in his claims.
The below excerpt (emphasis added) is compelling as background, particularly if one is inclined to believe that MI6 might have sought to entice the Syrian chemists to whom the Soviets outsourced their chemical weapons programme in the era when Novichoks are said to have been developed:
Syria may be the key to why he was poisoned earlier this month.
The Syrian government’s Scientific Studies and Research Centre, better know by its French abbreviation, CERS, was established in 1971. Certainly by 1983, and likely earlier, the USSR and its satellites had started to deliver chemical weapons to the centre together with delivery systems for choking, blister, blood and nerve agents. In the early Nineties it was reported that CERS was producing sarin, VX and mustard gas, having received the expertise, technology and materials from Russia. Early in 1992, Russia and Syria signed an agreement whereby Russia undertook to deliver new types of chemical weapons to Damascus. Among them was the infamous Novichok series of nerve agents recently synthesized at the Russian State Scientific Research Institute of Organic Chemistry and Technology — and the very type of poison that was administered to Sergei Skripal in Salisbury three weeks ago.
In early September 2017, Reuters and several media outlets reported an Israeli attack on a military site in Syria’s Hama province. The air strike killed two soldiers and caused damage near the town of Masyaf, the official statement said. A report from Jerusalem specified that the air strike was on CERS, after Western intelligence reports had linked the target to Syria’s chemical weapons programme. Reports from Moscow mentioned that the CERS facility was guarded by Russian Spetsnaz, the GRU’s equivalent of the British SAS, and staffed by the Russian research scientists.
In his article in The Times earlier this month, Ben Macintyre noted that the inclusion of Skripal in the spy swap was an anomaly, since he was not an American “asset”. The CIA had agreed to include him in recognition, perhaps, of the high quality of material Britain had shared from the so-called Forthwith files. But it was not only the old files and achievements dating back to the late Nineties that made Skripal valuable to the West.
[Skripal] was also the only source who could provide British and American intelligence with reliable estimates of [comment by Alex Thomson: or, indeed, who could spill the beans on Western co-opting or spoofing of] the Russian GRU activities in Syria. Although he didn’t know specific people and current operations, he knew the system from the inside and had practical knowledge and experience like no one else. Russia, smarting from the loss of CERS, knew that with [Skripal] gone it would be much more difficult for the British and Americans to analyse intelligence on chemical weapons coming from sources in the field
https://www.ukcolumn.org/blogs/keeping- ... d-articles
Linked with the latest revelations concerning Leonard Rink and Syria found here:
Very Interesting Syrian links/SVR involving our old friend, Professor Leonard Rink:
Rink Ринка
ЦУР проверил ближневосточные связи автора «Новичка»
The LRC checked the Middle East relations of the author of the “Novice”
https://medium.com/@tzurrealism/rink-d47d9e53b16f
Mudalal Khoury, Leonard Rink’s friend, is also a member of the board of the founding in 2014 of the charitable foundation “RUSSAR” (Rus and the Syrian Arab Republic).
The head of the fund is former 77-year-old Oleg Fomin, a good friend of the Assad family and the late leaders of Libya Muammar Gaddafi and Iraq Saddam Hussein.
Among his acquaintances was Sergei Skripal – they worked together in the personnel department of the Foreign Ministry.
In the section “Participants of the Fund” on the website among businessmen from the Middle East one can find a pleiad of prominent Russian figures: presidential candidate Sergei Baburin, former chief of the Main Directorate for International Military Cooperation of the General Staff of the Armed Forces of the Russian Federation Colonel-General Leonid Ivashov, Nelli Kuskova from the Combat Brotherhood “, Hieromonk Stefan and others.
reply ---So Skripal was essential for the West to unravel Russia’s supposed transfer of chemical weapon tech (including Novichok) to civil war stricken Syria next to Israel.
opinion was thought yes other than the scrubbed site that noted the effects of the molecular chain from the herbicide that killed the grazing mammals that died enmass.
Not a complete theory as yet, just connecting people and places, exploring angles.
These are the three I have spent most time on so far.
1. Sergei Skripal – Julia Skripal – Pablo Miller — Christopher Steele – Trump Dossier – CIA hit to shut his mouth – Novichok – Uzbekhistan – Edgewood – Dennis Rohrbaugh – Vil Mirzayanov
2. Sergei Skripal – Julia Skripal – Stepan Vikeev – Taitiana Vikeeva – Gasumyanov – Armenian Mafia – SVR – Potanin -Putin
3. Sergei Skripal – Julia Skripal – GRU Revenge -‘Gordon” – Karpichkov – Estonia – MI6 – Talanov – Leonard Rink – Novichok
4. Sergei Skripal – Julia Skripal – GRU Revenge – “Gordon” – “Karpichkov” – Estonia – Leonard Rink – Mudalal and Imad Khouri – Kirsan Ilyumzhinov -George Hasvani – Assad – Syria.
We will never really sort it out but the common thread was initially failed herbicide cover story based in factual pathologies as the iranians mapped some valence shields and later compounds bastardized on sites to propagate monetary gain on human slaughter as such and mapped.
Meanwhile the EU emperor wants Trump to acquiesce to no tariffs, no conditions, forever...
Israel has almost a million Russians inside its borders and they want to worry abouts roots
as we look above to some events seen to be forecasted rather clear. The owner of the garden is clear on some
points to the order of operations to be.
water wheat weather
The water is already know as the the tare that Jesus described in this parable was also known as the darnel seed, which looks almost exactly like wheat in the beginning stages of its growth. But after it grows a little more, it becomes evident that it is a weed, and it actually uproots the wheat.
When one of the farmer's workers asked him, "Shall we pull out the weeds?" the farmer replied, "No, you'll hurt the wheat if you do. Let both grow together until the harvest. Then I will tell the harvesters to sort out the weeds and burn them and to put the wheat in the barn."
Jesus told this story to point out that there are people in the church who have infiltrated our ranks. While there is wheat, there are also tares. We don't know who is who, necessarily.
The weather is the sign of the times and Mr. Missler will also be missed.
