https://www.zerohedge.com/sites/default ... k=CfXS-he0
so it begins, again
anyways, https://blj.ucdavis.edu/archives/vol-8- ... tml#_ftn61
CFMA in 1999 controls the actual inflation as the paper tigers control the velocity of the actual paperwork derivative contracts.
5. Sidetrack opponents with name calling and ridicule. This is also known as the primary attack the messenger ploy, though other methods qualify as variants of that approach. Associate opponents with unpopular titles such as “kooks”, “right-wing”, “liberal”, “left-wing”, “terrorists”, “conspiracy buffs”, “radicals”, “militia”, “racists”, “religious fanatics”, “sexual deviates”, and so forth. This makes others shrink from support out of fear of gaining the same label, and you avoid dealing with issues.
8. Invoke authority. Claim for yourself or associate yourself with authority and present your argument with enough “jargon” and “minutiae” to illustrate you are “one who knows”, and simply say it isn’t so without discussing issues or demonstrating concretely why or citing sources.
11. Establish and rely upon fall-back positions. Using a minor matter or element of the facts, take the “high road” and “confess” with candor that some innocent mistake, in hindsight, was made — but that opponents have seized on the opportunity to blow it all out of proportion and imply greater criminalities which, “just isn’t so.” Others can reinforce this on your behalf, later. Done properly, this can garner sympathy and respect for “coming clean” and “owning up” to your mistakes without addressing more serious issues.
Sentiment is now “broadly bearish” reports David Templeton of HORAN Capital Advisors.
Michigan sentiment declined from 101.4 to 97.8, missing expectations of 101.6. 29% mentioned trade policies. Those who did had weaker expectations and a higher inflation expectation. (Jill Mislinski).
http://blog.yardeni.com/2018/04/real-gd ... o-old.html
Hard to get to the new normal when they never understood the old normal
This is a contest where animals adopt different roles like “owner” and “intruder” in a territorial conflict, and where the winner is the individual prepared to persist longer. The term incomplete information refers to mistakes in the identification of roles. The idea by Parker & Rubenstein (1981) is mathematically worked out and confirmed that there exists only a single evolutionarily stable strategy (ESS) for the model with a continuum of possible levels of persistence and no discontinuities in the increase of cost during attrition. The ESS prescribes to settle the conflict according to “who has more to gain or less to pay for persistence”. The only evolutionarily stable convention is thus to give the player access to the resource who has the role which is favoured with respect to payoffs.
Syrian president Bashar al-Assad must understand that "his provision of a forward base for Iran and its proxies endangers Syria.
signal emissions
Quakers were punished by each side for their supposed allegiance to the other.
At the start of the Revolutionary War, the Friends took a neutral position and were persecuted by both British loyalists (Tories) and American Whigs. Quakers did raise money and sent supplies to assist civilians. In 1777, seventeen Philadelphia Quaker leaders were accused of treason and exiled to Virginia by the Whigs, but the following spring the fourteen who survived were released without trial.
Quakers who stuck by the sect’s pacifist teachings had a tough time during the American Revolution, often lumped in as Tories by Patriots, and subject to spasms of popular abuse, official writs confiscating their property, and other indignities. Prejudice occasionally exposed Quakers to the severest punishments for perceived crimes.
We are under the order of natural law on his foot stool as a compromised position. We will compromise until duty to family arises at the rally point. That day you pray never comes. The extreme positions are seen at both ends of political human error.
http://gdxforum.com/forum/viewtopic.php ... ent#p35283
Meeting over.
Double entendres generally rely on multiple meanings of words, or different interpretations of the same primary meaning.
https://www.afp.com/en/news/831/model-c ... oc-1406zd4
http://www.bbc.com/news/world-us-canada-43786365
https://archive.org/details/pdfy-eDNpDzTy_dR1b0iB
https://www.pressreader.com/philippines ... 5305482280
The whole point of the chaos is to remove opposition to the pipeline. The Brits kept arming up the Indians after they lost the Revolution. Those Indians raided the settlements on the frontier. That is a good part of the reason we fought the war of 1812. The Empire never packs up and goes home. It simply develops another angle of attack. This little enterprise will flood the MENA with more arms and ammunition further destabilizing the region. Chaos in the region causes gas prices to rise which aids the oil producers the world over.
We're talking about people that need 70% of their economy to be run by Bangladeshis and Pinoys.
As noted your kadesh is seemingly appearing.
Salem South Carolina was there, and even more strange was it was the SAME EXACT distance away from dead center totality
line as Salem in Oregon! It passed through seven Salems.
The next eclipse after August 21st will be April 8th 2024. Guess which town is where the two cross, you guessed it.
Salem Kentucky.
The judgement seal ends.
thread: Anderson kadesh kaduri 2018 amos
those with an eye listen for the footsteps in His word
“Well, I wouldn’t mention it,” Mr. Hayes said, “but if they ask, you should tell them.” In any case, he added, everything was done in writing,
so it wasn’t much of a secret.
Dated and noted...
The new dmz , between ears.
Twenty Pieces of Silver for Joseph and Thirty Pieces for Christ.
After all, keeping friends and enemies off balance is Assad's art of survival.
Read more: https://www.americanthinker.com/article ... z5CwpbUvbS
thomasglee
Post by thomasglee »
If you really want to see Gen-X'ers at their worst, just look at LinkedIn. The amount of time that Gen-Xers spend there promoting themselves is sickening. They spend so much time posting stories, personal anecdotes, etc, I wonder how any of them have time to work. I am amazed at how much self-promotion goes on there. In the past, we would have properly recognized it as narcissism, but today we call it, "personal branding".
thomasglee wrote: > If you really want to see Gen-X'ers at their worst, just look at
LinkedIn has an effective cutoff age of about 30, which makes it
pretty useless. Here are a couple of articles from 2014 and 2016:
** Age Discrimination on LinkedIn Hitting ever Younger Ages?
** http://wolfstreet.com/2016/06/17/is-age ... er-people/
** How job recruiters screen you on LinkedIn
** http://www.marketwatch.com/story/how-re ... 2014-05-02
thomasglee wrote:If you really want to see Gen-X'ers at their worst, just look at LinkedIn. The amount of time that Gen-Xers spend there promoting themselves is sickening. They spend so much time posting stories, personal anecdotes, etc, I wonder how any of them have time to work. I am amazed at how much self-promotion goes on there. In the past, we would have properly recognized it as narcissism, but today we call it, "personal branding".
http://www.middleeasteye.net/essays/cou ... orld-order
The new brand offers little since we know what fuels it also.
What can be saved will be. The DMZ is between the ears.
https://www.youtube.com/watch?v=xolzz93wTWo
thomasglee
Oh, I have no disagreement with you here. I was just pointing out the narcissism that takes hold on LinkedIn. And most of the worst offenders seem to be around my age (50).
Much deeper than that.
https://img.4plebs.org/boards/pol/image ... 815566.jpg
May 14, 1950 Political party‎: ‎Green
Deeper State knows “People naively believe that if you take deep learning and scale it 100 times more layers, and add 1000 times more data, a neural net will be able to do anything a human being can do,” says François Chollet, a researcher at Google. “But that’s just not true.”
https://www.wired.com/story/greedy-brit ... -learning/
Only fools deny point the programming data will be nothing less than another purple gang murder subsidiary with facial recognition inputs operands. Capone only negotiated with the Purples. Last time I went to the Border the Canadian OCR system then was good enough as hello MR. XXXXXXXX from the Customs attendant and I replied with a smile and forwarded nice OCR as my wife looked puzzled many decades ago.
Sat Apr 07, 2018 10:29 am
I would rather her read a written script than tow the busted brand.
https://www.youtube.com/watch?v=KEWZntPhQ4k
April 12, 2018 11:46AM
https://thepoliticalinsider.com/nancy-p ... nt=2219414
Why to ex-democrats as such have more empathy than the actual current DNC slaughtership....
Functional magnetic resonance imaging (fMRI) measures the small changes in blood flow that occur with brain activity.
We are just more concerned with the very young unable to protect themselves and the elderly we truly care for.....
Users browsing this forum: aedens, Bing [Bot], Google [Bot] and 1 guest
