Behold, days are coming," declares the Lord GOD, "When I will send a famine on the land, Not a famine for bread or a thirst for water, But rather for hearing the words of the LORD. "People will stagger from sea to sea And from the north even to the east; They will go to and fro to seek the word of the LORD, But they will not find it. "In that day the beautiful virgins And the young men will faint from thirst.…
Galatians 3:5 So again I ask, does God give you his Spirit and work miracles among you by the works of the law, or by your believing what you heard?
We are consolidating what we can to put a floor under children's feet.
Matthew 10:42 "And whoever gives one of these little ones even a cup of cold water because he is a disciple, truly, I say to you, he will by no means lose his reward.”
a from the grain colony
http://gdxforum.com/forum/viewtopic.php ... 130#p29816
https://rehmat1.com/2015/06/18/magna-ca ... 800-years/
http://whoismonsanto.com/glyphosate-monsantos-killer
http://www.mdpi.com/1099-4300/15/4/1416
He did not justify his action but accepted that he was taking guilt upon himself as he wrote "when a man takes guilt upon himself in responsibility, he imputes his guilt to himself and no one else. He answers for it... Before other men he is justified by dire necessity; before himself he is acquitted by his conscience, but before God he hopes only for grace." Dietrich Bonhoeffer
As before In Hilferding’s view, the banks not only financed the industrial expansion of capitalism into dependent and colonial territories, but also restrained competition between capitalists and financed their cartels. If crises arose, they were due to disproportions in production and class struggles. By stabilising the markets and finances of the capitalists in their cartels, banks were able to shift the costs of those crises onto non-cartelised capitalists. Because it concentrates control over industry, finance capital facilitates the eventual socialisation of the means of production.
Hilferding Finance Capital A Study of the Latest Phase of Capitalist Development, edited and introduced by Tom Bottomore, translated by Morris Watnick and Sam Gordon, London: Routledge and Kegan Paul, 198,1 chapters 20 and 25.
Basically the legal cartels asserted themselves from the recent unproductive capital forces to actual market demand.
I will repost the findings from the magna carta period notes we forwarded also as social usury issues.
Extraction
During the extraction step the data is extracted from the source systems and is made available for the next steps. The main goal is to obtain all the data from the sources so that the impact on the performance of the source systems is minimized. Generally, the data from the source systems is stored 1-on-1 in a ‘Staging Area’, which will serve as the input for the processing in the transformation phase.
Transformation
In the transformation stage, a combination of rules is applied in order to transform the source data into the desired output. Examples of this are the bringing together of similar data from different source systems, the filtering of data, adding new calculations on the basis of data from the source systems, and converting measured values to the same units. This last example is for example, converting all currencies into Euros. Pivoting data, or execution pre-defined validation rules are also examples of Transformation steps.
Load
After every transformation is performed, the data is loaded into the end goal, which is usually a Data Warehouse. Other goals, however, are not uncommon, for example, exporting text files so as to deliver these to legislative bodies or trade associations. Sometimes the enriched data is loaded back into one or more of the source systems after the transformations.
SAP Data Services’ (BODS) advantages
In The Netherlands BODS is mostly used to build ETL processes. Besides many conventional databases BODS also supports, applications (such as SAP, PeopleSoft and Salesforce.com), files (such as CSV, Excel) and mainframes. Newer technologies such as web services and Hadoop (blog: SAP HANA and Hadoop) are also supported as data sources. There are, however, other products that can also do this. How does BODS set itself apart from the other players in the market?
The biggest distinction is the tight integration with other SAP products. This is especially evident in the extensive opportunities to take a look at data using SAP ECC and SAP BW. The ability to use the extractors, SAP BW uses these to take a look at data in SAP ECC, directly from BODS as a data source is unique. BODS is the only ETL solution on the market in which this is possible. In addition, the integration with SAP HANA, SAP's in-memory platform, is much more extensive than in other ETL tools available on the market.
Finally BODS, can integrate structured data from databases, applications and such, but also unstructured data as a data source. Data Services is able to extract sentences from files from applications such as Word, Powerpoint, Excel, PDF and Outlook, as well as “understanding” data streams such as Twitter and Facebook, on a logical level. BODS can even analyses sentiment from these.
Bottom line: the big sequential bounce in wages was driven entirely by the January minimum wage increase, and the low December base effect. Expect this sequential increase to renormalize in February when the base now reflect higher minimum wages.
Extraction
Transformation
Load
The constitution stipulates that the President must be Muslim in Syria.
Many Circassians are attempting to return to Russia (to their ancestral North Caucasus homelands)
Armenian Christians have been detained and tortured by the Assad regime, leading them to dismiss the regime's claim to be the protector of Christians.
The largest Christian denominations in Syria are the Greek Orthodox church
All sects of Christians are being eliminated as we know.
Russia and the States have interests that may intercede when the east and west
meet.
“The encounter has been under preparation for a long time — it wasn’t improvised,”
http://gdxforum.com/forum/viewtopic.php ... 110#p29777
meet.
- nicholas-punches-arius.jpg (27.53 KiB) Viewed 4347 times
I guess E-trade is saying the market volatility has passed. They will once again let me purchase $4 worth of stock for every $1 I have. Don't worry, I am not buying on margin, just think this is interesting...
I just had the same thought but will wait until after march, or as noted until spring.
The thought of the ripples of the dying Old Order always comes to mind.
The attention span is micro seconds with people and the market.
The demographics suggest other intent as its faded is my conviction actually.
It takes a few years for even basic common sense to the affiction of others
in the so called civilized parts of planet. I just note the visceral antagonisms
which preclude agency's action we noted as kill switches earlier. They never left the floor
either. No matter the wheel is in motion.
Then they will deliver you to be persecuted, and will kill you, and you will be hated by all nations because of My name.
At that time many will fall away and will betray one another and hate one another.
Many false prophets will arise and will mislead many. Because lawlessness is increased, most people’s love will grow cold.
Others seen the next step coming also. https://archive.org/stream/CreatureFrom ... 7/mode/2up
page 282 http://www.zerohedge.com/news/2016-02-0 ... -americans
So it begins H as you noted "A colleague of mine got turned into a vegetable. I talked about that here in these pages. Once they turned him into a vegetable, the personnel lawyers unilaterally gave him a disability check and health insurance for the rest of his life. There was no court case - they don't want the record of it. These people make Stalin look like an amateur." Aedens was right when he said they make the Soviets look like pussies.
page 563 https://archive.org/stream/CreatureFrom ... 3/mode/2up
For the unintuitive as we warned "useful and cheerful" sceptics: asymmetric paternalism: states that paternalism should be invited if it bestows large benefits on those who make errors in judgment while imposing little or no harm upon those who are fully rational.
The pebbles in the living stream of truth are worn smooth and round by friction.
Sunday Morning, March 30th, 1862, by C. H. SPURGEON
Hosea 10:13 But you have planted wickedness, you have reaped evil, you have eaten the fruit of deception.
Because you have depended on your own strength and on your many warriors.
He will not be mocked.
water wheat weather
water wheat weather
