"why do you come here instead of staying and trying to make it better at home?" The men/boys all say the same thing..."because we are taking over Europe, we are going to take over your country, it's happening"
Time line (Daniel 9)
June 2011 + (2520 Days + 30 Days + 45 Days) = July 2018
2018 July 27th Tu B’Av, central lunar eclipse, “Bull’s-eye Blood Moon”, directly in line with Jerusalem.
Time line (Luke 21:32, Psalms 90:10, Dan 9)
1948 + 70 years = 2018
1968 + 50 years = 2018
2011 + 7 years =2018
From the slaughter of the poor which choked the rivers with the dead, came in the Portuguese language warnings of
prophecies revealed to visionaries in South America and Central America....
What I have seen they are painfully correct.
Not my opinion either...
From the slaughter they warned us what will be soon here. From the reports in the mid decades then they have
been frightfully correct since the warnings where ignored. They already knew they would be.
This checks out with reports from numerous sources. Many we covered here already.
I will never abandone Hope since the price has already paid for us.
Last year it was noted on policy.
In answer to the question: Do you have anyone dependent on you replied:
2.1 million illegal immigrants,
1.1 million crack-heads
4.4 million unemployable scroungers
900,000 criminals in 85 prisons
650 idiots in Parliament and the whole of the European Commission
His response was deemed unacceptable.
In response, he asked "Who did I miss out?"
Now over here details are pointless http://thefederalist.com/2016/01/26/oba ... t-tyranny/
http://gdxforum.com/forum/viewtopic.php ... 000#p29560
What's going to happen in 2018?aedens wrote: Time line (Daniel 9)
The butter and bullets swamp idiots will get you killed, as the Sampson option plays out.
Doctor Quigley was incorrect that the alleged scroundrels would be voted out of Office.
They will be laid waste and the spoils are taken from the crafted narrative.
As we warned, what they want is under the dirt.
Or cough up $500.00 bucks and be a wheat producing slave to the moon cult.
Cluster bombs and Napalm rule the day just as war on the ecology is doing just fine.
Europe will be a cinder as they are annialated and regroup.
Rome will be reborn and Amos will be seen and fulfilled.
They are getting nervous since a few more years of college you can simply ignore it.
http://www.liveleak.com/view?i=a01_1453627021
Migrant beats and spits on woman in Sweden because she defended an elderly woman he was trying to rob.
- The_cruel_massacre_of_Naarden_by_the_Spanish_in_1572_(Jan_Luyken).jpg (25.04 KiB) Viewed 5848 times
Russ and his spendid epeens are trying to catch up.
- US-Bombs-Dropped-in-2015-300x184.png (16.5 KiB) Viewed 5843 times
http://www.americanthinker.com/articles ... dists.html
http://www.americanthinker.com/articles ... ments.html
http://www.hellstormdocumentary.com/
This is only the beginning of dire events upon mankind from 2016 to 2038. So it begins as translated recently from 2006 from the
slaughter in central america. They took the time to tell you about the mark in your fore head.
The Beast has no conception of Her adornment. http://www.huffingtonpost.com/2012/08/0 ... 10133.html
“Fight the good fight of the faith. Take hold of the eternal life to which you were called when you made your good confession in the presence of many witnesses.” Timothy 6:12
Matthew 10:42 And whoever gives one of these little ones even a cup of cold water because he is a disciple, truly, I say to you, he will by no means lose his reward.”
from thread notes Thu Aug 02, 2012
It’s probably necessary to point out explicitly here that these classes aren’t identical to the divisions that Americans like to talk about.
http://thearchdruidreport.blogspot.jp/
What's going to happen in 2018? The point is simply that it already has happened.
http://www.fivedoves.com/letters/june2011/luisv611.htm
I have friend who let me read, if Ii remember the date correct from 1865 the effects to be in a rather unbiased view.
Staggering piece of work to affairs in the day. I also enjoyed Sir. Robert Andersons work to
conjectures we see also.
http://gdxforum.com/forum/viewtopic.php ... ert#p27831
Natives are always restless these days. Beem me up Scotty. The meme of the moment is drift and recovery for the usury
paper tigers.
paper tigers.
http://swedenreport.org/ there toast
https://www.youtube.com/watch?v=rpkm6iSd--c
yellow cake and metal and ditto on the other site also
avarice
avarice
Another old post to ponder in light of the recent news.
Higgenbotham wrote:Now let's say at some point in the future there's a water system in Detroit or some other major city in a state of disrepair and the water comes on for a few hours per day. The water system engineers find a way to get the water pumped the required 20 miles and someone out in the far reaches of the system in a suburb of Detroit can open their tap for a few hours per day and get some water. Problem solved, right? No, not in this case. The reason is that all the piping is underground. The underground piping is going to have leaks in it. At present there are water systems that are losing substantial amounts of water to leaks in the system piping. That occurs in the midst of drought conditions. Getting back to the point of this, a water system that has pipe leaks must be pressurized all the time. That is because the underground pipe has pressure acting against it and if the pipes aren't pressurized from the inside all the time you will be basically drinking the runoff that ends up in the soil around those pipes. Most of which is probably contaminated with chemicals and pathogens around the distribution system of any large city. So while it's OK for your lights to flicker on and off a few hours per day, it's not OK for your water system to operate in that manner.
http://water.me.vccs.edu/concepts/pressuredistr.htmlWater pressure is an important factor to consider when planning a distribution system. As a rule of thumb, the water pressure throughout the distribution system should be no less than 17 PSI. In many high value districts, distribution lines are designed for a normal pressure of between 60 and 70 PSI.
Low pressure in the mains can be a health hazard since the pressure in the pipes keeps contaminated water from entering the mains. If the pressure in a pipe is too low or is negative, contaminants from nearby ditches, cross-connections, and poor quality house plumbing can be drawn into the water system.
Investigations have proven that most water-borne disease outbreaks are the result of contamination of water after it is pumped into the distribution system. To prevent contamination, an adequate chlorine residual must be maintained and the residual pressure should never be allowed to fall below 20 PSI. The Virginia Department of Health issues an advisory for extra-precautionary measures during periods of low pressure or vacuum.
If the system has elevated storage nearby and enough water can be pumped to elevated storage while power is on to hold pressure in the system the rest of the day, then those people will be OK.
It's surprising how difficult is was to find a reference which describes this in layman's terms. These concepts are very basic to the operation of the infrastructure of a civilization and it seems this knowledge has almost been lost. This reference came from a web site called Virginia Community Colleges.
Just seen that venturi effect. The old well point was past shot so a new 10 inch was put in.
A few Segments up line had holes rotted in the pipe over a fifty cents piece in size.
Design was ~400 gpm and Maximum Contaminant Levels (MCLs) are not a issue since its industrial.
Leaked to around 250 gpm max flow.
Lab work sample indicated normal above threshold pressure. Turbidity was noted of course at lower gpm.
As we know they metered losses from Metd at ~40 percent
Anyways, the first words out of a ice picks yap of a sycophantic nepotist and classic DSM-IV-TR malignant narcissist
was I blew the line up when I energized the pump. As you forwarded H every thing you stated has been
seen with the atypical work environment subterfuges. The snowflakes are special when immunity from detrimental effects
is a mainstay. A few years to go.....
http://www.synonyms.net/synonym/ass-kisser
http://www.zerohedge.com/news/2016-01-2 ... 015?page=1
http://gdxforum.com/forum/viewtopic.php ... 006#p29726
Users browsing this forum: aedens, Google [Bot] and 1 guest
