"Too Many Zeros": China's Stock Bubble Proves Too Much For Computers
http://www.zerohedge.com/news/2015-04-2 ... -computers
"The exchange's trading turnover exceeded 1 trillion yuan ($161.28 billion) for the first time on Monday, but the data could not be properly displayed because its software was not designed to report numbers that high."
I am confused -- are we talking finance or astronomy?
Universalists and the Tribalists still pay taxes to butcher the gray areas to sleep better.
Same as it ever was, since when a person's limit for "connections" is reached the human brain
as reported resorts to some combination of hierarchical schemes, stereotypes, and other simplified
models in order to simply understand. The numbers may somewhat change for the specified study
but it functions around 150 to 260 as Dunbar and many others assert as a norm.
The function of Balkanization is the control dial for the dialectic. As we noted they are unleashed
on the unsuspecting. The narrative is simply to what side of the bars is it now and we should of been friends
since the irony was laid down long ago as who had time to follow that.
And the disturbing last paragraph is excised here:
Within the next generation I believe that the world’s rulers will discover that infant conditioning and narco-hypnosis are more efficient, as instruments of government, than clubs and prisons, and that the lust for power can be just as completely satisfied by suggesting people into loving their servitude as by flogging and kicking them into obedience. In other words, I feel that the nightmare of Nineteen Eighty-Four is destined to modulate into the nightmare of a world having more resemblance to that which I imagined in Brave New World. The change will be brought about as a result of a felt need for increased efficiency. Meanwhile, of course, there may be a large scale biological and atomic war — in which case we shall have nightmares of other and scarcely imaginable kinds.
Thank you once again for the book.
Yours sincerely,
Aldous Huxley
For proper context on Aldous Huxley one has to keep in mind that his brother was an ardent eugenicist and laid the foundations for the Transhumanist movement. As founder of the UN's UNESCO.
Nothing is lost but context.
If machines can placate the masses so be it they already said.
http://www.cultofmac.com/311171/crazy-i ... -rankings/
aedens wrote:Universalists and the Tribalists still pay taxes to butcher the gray areas to sleep better.
Yours sincerely,
Aldous Huxley
aedens --
If you have read "The Alien Interview " http://www.amazon.com/Alien-Interview-L ... 0615204600 -- what is described above is the working's of the Earth prison for "problem individuals " as run by the " Empire " an interstellar "civilization".
Getting out is the trick and death is not an escape for one is recycled back in,( note some religious dogma about death and rebirth) the book is listed as science fiction -- but is it? -- "1984" and "Brave New World" are listed as science fiction but are they? or are they instruction manuals?
Evidence points to facts.
The Great South African Land Scandal
Jul 19th, 2012 By Dr. Philip Du Toit.
In 2007, South Africa became a net food importer for the first time since its founding in 1652.
Life is a complicated process of organizational processes. I only named three above.
As we related clearly earlier why did the czar protect the mint in california for lincoln and the southern boys
eliminated as they insisted on educating the children in traditional values destoyed by the upcoming and known keynesian veils listed.
As you can see from clear evidence some locals are not able to move forward as we ponder the hundred or so
jiffy pop nuke reactors, and as we witnessed recently the cme that would caused this realm to cease to exist for 100,000 years.
Given the transhumanist maximize profits cult, and ignore the rest rotting under our feet should we install the
300 percent robot over the 100 percent online. Point is above and below they eat anything even as the root as locusts as we are warned.
http://mgafrica.com/article/2015-04-21- ... c-attacks/
As we know G the question was observed as what does Sismondi's theory amount to that the home market shrinks with the development of capitalism amount to. We know that inertia of intent seldom meets interpetation and why. One says write it, one deletes it, one just ignores it.
http://www.gata.org/files/BeardsleyRuml ... an1946.pdf
G, I have not read that rendition of those files since checking up on footnotes, as much as possible saves more time. On who wanted
to derive a point to consider.
Is there a problem?
http://www.infowars.com/report-jpmorgan ... sit-boxes/
"As of last month, Chase has also instituted a new policy which, “restricts borrowers from using cash to make payments on credit cards, mortgages, equity lines, and auto loans,”
why?
gerald wrote:Is there a problem?
why?
Largest Bank In America Joins War On Cash
http://www.zerohedge.com/news/2015-04-2 ... s-war-cash
Buiter defended his "controversial" call for a ban on cash, as Bloomberg reports:
“The world’s central banks have a problem. When economic conditions worsen, they react by reducing interest rates in order to stimulate the economy. But, as has happened across the world in recent years, there comes a point where those central banks run out of room to cut — they can bring interest rates to zero, but reducing them further below that is fraught with problems, the biggest of which is cash in the economy.
In a new piece, Citi’s Willem Buiter looks at this problem, which is known as the effective lower bound (ELB) on nominal interest rates. Fundamentally, the ELB problem comes down to cash. According to Buiter, the ELB only exists at all due to the existence of cash, which is a bearer instrument that pays zero nominal rates. Why have your money on deposit at a negative rate that reduces your wealth when you can have it in cash and suffer no reduction? Cash therefore gives people an easy and effective way of avoiding negative nominal rates. Buiter’s note suggests three ways to address this problem:
Abolish currency.
Tax currency.
Remove the fixed exchange rate between currency and central bank reserves/deposits.
Yes, Buiter’s solution to cash’s ability to allow people to avoid negative deposit rates is to abolish cash altogether. (Note that he’s far from being the first to float this idea. Ken Rogoff has given his endorsement to the idea as well, as have others.)
In "The Alien Interview" some of the prisoners were those who violated income tax regulations" and monetary rules --- fiction?
G
http://gdxforum.com/forum/viewtopic.php ... nal#p26969 = http://wolfstreet.com/2015/04/23/strate ... y-fridson/
The basket of hanging fruit seen before. Still they linger in the limitations of the dialectic.
For the Middle East and North Africa there two main categories of figs in question.
The commercially exploited one is known as Ficus Carica, the other one being the sycamore fig.
The sycamore fig also has edible fruits, but of inferior quality to the Caric.
http://www.wnd.com/2011/12/379829/
Going forward the seal will be not understood. And that’s what took place in 2003 alone.
If you seen what we posted here some time ago to top it off you can see why the seal is complete
any the only who can break them. The abrogated views are stunning today.
http://wolfstreet.com/wp-content/upload ... 1-2015.png
As we noted the book into 2018 will be what not who.
As before it was written “Very well, then, he is in your hands; but you must spare his life.” Job
aedens -- interesting reads.--- Prophecy is a very interesting subject and must be approached with care. Having experienced precognition regarding "events" both "personal" and "other wise", from "days" to years in the future, it is not to be taken lightly. Having said that, one must not become paralyzed by "possibilities". For you see, precognition can be about events that "will be" or about events that "might be" and can be changed. Knowing which is which is the issue. One of the major problems to day is not being able to call a spade a spade and understanding that to fully understand "science" one must view science from a spiritual perspective, and that with "science" comes responsibilities. Note I did not say theological perspective. --- Having had a discussion with two "pagans" in Iceland it is interesting to note that they have a better understanding of "nature" then many Christians, or Jews for that matter. --- It is interesting to experience an important pagan site such as "the standing stones of callanish" https://www.google.com/search?q=the+sta ... 9&bih=1087 it has a primordial feel, different, deeper and more powerful then a cathedral, the walling wall, or a grand mosque, all of which are very impressive, but feel superficial.
cheers
https://mises.org/library/pretense-knowledge
What we discussed before. Nothing Alien about imported vote blocks or life boat ethics, just dates.
"disciplines that deal with essentially complex phenomena are nothing new"
And Deuteronomy 4:28 of you see what you want to.
Deuteronomy 28:36 and still they wander.
We know the results to be.
https://www.youtube.com/watch?v=OrcTsxs-anU
Users browsing this forum: aedens, Bing [Bot] and 2 guests
