Xeraphim1 wrote:
JCP wrote:
John wrote:** 17-Jul-2019 Comfort Girls
And I can show you a thousand that state how hellish it was.
https://www.smh.com.au/national/austral ... 33d4o.html
The Japanese will be exterminated at this rate.
And it was also 74 years ago. At some point your grievances lose validity.
Well, I suppose it helps if the perpetrators show an ounce of genuine remorse. Since the Japanese really don't have any remorse, they are going get ground into powder. But hey, that's ok. The surviving Japanese diaspora could forgive and forget 74 years later...
Post by FishbellykanakaDude »
Millenial83 wrote:...Millenial, I was typing on a phone so calm down.
Misspelled it again. Gotta love Millennial thoroughness.
Millenial83
Post by Millenial83 »
Address the actual argument. The US is clearly a powder keg ready to blow, tonight's rally chant is just the start.
It's your responsibility, as the proposer of the case, to justify your contention that an ID Group based civil war is "on the brink".
Your cadre (millennials) is apparently not acquainted with the idea of burden of proof, or due process.
..not much of a surprise, actually.
Millenial83
As even John has written in his book and in his various analyses, often in a Crisis Era the ideas of the previous Awakening are either enshrined permanently or are rejected. The ideas of this cycles awakening were Civil Rights for Blacks, opening the door to American to non-white immigrants (1965 Act) and family destroying feminism.
As the demographic changes are now coming to a head from the 1965 Act and illegal immigration, the white majority is starting to feel it's back up against the wall and is pushing back, hard, hence MAGA, and rightfully so.
I foresee the trigger being the 2024 election, where only for demographic reasons Texas flips blue, because it turned brown. Once that happens the grassroots right will understand that demographics is about to end all national political power and the Civil War will begin. The two sides are obvious the Red Side: Traditional (Real) White America vs Blue Side: Weak ubran brainwashed self-hating whites, Jews, Blacks, Hispanics, Muslims, and Homosexuals. Obvious the red side would win in this fight and in the process Make America White Again.
We can all feel it, the fight that is coming in the Crisis is internal, not external. There is no "Bomb China" chant spontaneously erupting Trump rallies but "Send Her Back" is. "Send Her Back" will morph into "Send Them All Back!"; blacks to segregation, post 1965 non-white immigrants back where they came from (born here or not), women back to the home, gays back to the closet as the Civil War kicks off.
** 17-Jul-2019 Civil war
Millenial83 wrote: > As even John has written in his book and in his various analyses,
> feminism.
This is almost completely fatuous nonsense, so much so that I'm
wondering if you're posting it as a joke. The idea that "traditional"
Whites will start a war with "self-hating whites" or gays or whatever
is really silly.
Also, your posts are getting close to crossing the line into hard core
racism. Please don't force me start deleting your posts, which I
definitely do not what to have to do, but will if forced to.
Beyond that you're describing a political split (red vs blue), and
claiming that it will trigger a civil war. There are sharp political
splits at one time or another in every country, and so if your
reasoning were correct, then we'd see a lot more civil wars. But we
don't.
When there are civil wars, there's always a lot more than a political
split. It's Hutus vs Tutsis, it's Alawites vs Arabs, it's Hindus vs
Buddhists, it's Christians vs Muslims. Actually it isn't even
Christians vs Muslims so much as farmers vs herders.
Nobody was chanting "Bomb Germany" or "Bomb Japan" prior to WW II, but
we ended in wars against them anyway.
Even the American Civil War did not have the characteristics of an
internal civil war, since there was no slave uprising. Instead, it
was a war along a geographic fault line, north vs south, with southern
Blacks supporting the Confederates.
So America has no history of the kind of civil war you're describing,
and there's no sign of one forming.
With regard to the 1960s Awakening era, yes, a fault line can form and
turn into a civil war during the following Crisis era, but nothing
like that happened. In particular, there was no fault like between
blacks and whites. Also, there can never be a civil war along a
feminism fault line, because there's too much fraternizing with the
enemy.
John, what font and font size did you use in your book? The book is 6X9. right?
John wrote:... Also, your posts are getting close to crossing the line into hard core racism. ...
..passed that mark about 3 parsecs back. <chuckle!>
Millenial83 wrote:... I foresee the trigger being the 2024 election, where only for demographic reasons Texas flips blue, because it turned brown. Once that happens the grassroots right will understand that demographics is about to end all national political power and the Civil War will begin. The two sides are obvious the Red Side: Traditional (Real) White America vs Blue Side: Weak ubran brainwashed self-hating whites, Jews, Blacks, Hispanics, Muslims, and Homosexuals. Obvious the red side would win in this fight and in the process Make America White Again. ...
For the "Real Americans™" to have an hope of "uprising" without being utterly mowed down by the US military, the non-"Real American™" supporting Congress Critters would have to be "moved out of the way permanently into cavities in the ground", which is not going to happen.
The rest of your scenario is fully dependent on the above non-occurrence, so try to figure out a more reasonable scenario.
I'm rooting for ya' buckeroo! More and better fiction from you is JUST around the CORNER!
..in the timeless words of Rob Schneider, "YOU CAN DO IT!"
..oh, and Adam Sandler too.
Millenial83
Easy, in this scenerio there will be mass desertions from the military to fight with the Red Rebel side, since a large portion of the military is drawn from those places and people.
Users browsing this forum: No registered users and 14 guests
