Presumed nothing good came out of meeting in Sudan or will.
Egypt's water will be cut off anyways was the warning to issues discussed.
Grand Ethiopian Renaissance Dam (GERD)
For the recent sediment yield reported at El Diem, and estimating a specific weight on the order of 1.0 t/m3 for sediment deposits, the reservoir’s dead storage capacity is sufficient to trap ~100 years of inflowing sediment. This is an accepted conventional design criterion, but it does not result in long-term sustainability.
Egypts erosion losses alone will seal its fate was offered.
The recent sediment yield is 835 t/km2/yr across the 176,000 km2 watershed tributary to the El Diem gage. A recent study by the Water and Land Resource Centre (WLRC) using a very detailed modelling approach indicates that sediment entering GERD will be in the order of 287 million M3/year (WLRC, 2017 unpublished), much higher than previous predictions.
Many issues go to another loot and scoot operation and debt failure map take over.
As development proceeds, financing structures to facilitate productive investment become more important,
for example, to allow the purchase of a communal truck to transport products to market instead of selling to a middleman at depressed prices.
https://www.hydropower.org/sediment-man ... e-dam-gerd
https://www.worldhydropowercongress.org ... 3-congress
Already the blood flows as the slaughter begins.
The masses may start to believe their own observations and logic. Each side will napalm you.
Something about focused measures.
https://www.juancole.com/2018/12/sudans ... diers.html
child meat bags not alreadt sent of kidnapped to die for the saudi appear to have had enough also
https://www.hrw.org/news/2022/02/23/glo ... k-conflict
https://www.youtube.com/results?search_ ... from+sudan
SUDAN: Saudi aircraft on fire at Khartoum Airport
https://youtu.be/8cPZJJkN_Zk
https://www.youtube.com/watch?v=FlCIY4nk5To pretext
2 ops underway is the current view to loot to collapses
again
its up to you to avoid the /tar
even when trepanning was in the stream on their devices
entertainment effect was rather elevated that week for less than a handful of the ips.
zone c
11 killed, 27 wounded
no one under 33 will buy ev
bishtardian mobile ash trays
Sorry swamp demsheviks you are known past stupid and worship molek and just sickness in evil practices already known. Darkness. Toxic.
Your eunaz root kit handlers are just disconnects.
The fundamental struggle is between capitalism and socialism, between true private ownership over the means of production and their collective ownership. Any intervention, even those thought to be benign, eats away at private ownership rights and pushes the economy toward socialism. lvm
1. unbridled enthusiasm
2. mass confusion
3. sudden disillusionment
4. search for the guilty
5. punish the innocent <-------------------
It's not that government has lacked information needed to fix the problem. It is institutionally incapable of bringing about the desired result, since the principles of profit and loss, private property and contract, enterprise and entrepreneurship, do not exist in government. Any Government operates with an eye to its own short-term survival, and those of its connected interest groups, and nothing else.
Consumers are digging in until it fails.
It is.
Socialist leaders always deny their economic policies have failed. The goal of socialism is communism. Vladimir Ilyich Ulyanov
Brandon legacy is sealed. Cantillion cargo cult is impossible to miss.
Former CIA analyst Larry Johnson has found a smoking gun: it's simply not possible for anyone with access to secure military systems to have gotten one of the documents, a CIA product that would reside only on entirely different systems.
Everything you see is Narrative Control you see. First rule is sap server in the shitter and files in a garage is the master plan
as a coke heads slamming hookers in a cash spin cycle of foreign cash grift. The older plan booted out the corruption and the biscuit eaters
mopped up the rest of the plate as they run out of fly over blood bags to loot over 125 percent of gdp as it collapses 14 of 15 times in history
as lie cheat steal think it different this time. The message was clear your charter is null from the Creator and given over to depravity on His
Garden sealed for His day alone. Washington, Jefferson and Lincoln told you what and how it would be done. The flyovers we care for are also past aware of the current swamp disease as all out and nothing in balance of trade.
https://tradingeconomics.com/united-sta ... e-of-trade
Reagen democrats are done with these demshevik thieves and debased perverted woke worthless shit bags. Your reality avoidance emote drones are as bad as blm top self retards looters.
https://www.youtube.com/watch?v=dDwoJSsXqSE step by step and yes since 1971 we get it.
He may be correct with the June call and I will not avoid the map seen on that demographic view.
Due diligence is on you. Ramsey world put all your assholes on beans and rice and yea we understand deficit retards you owe yourself cult uniparty lunatics.
The statistic shows the national debt of the United States from 2017 to 2021 in relation to the gross domestic product (GDP), with projections up until 2027. In 2021, the national debt of the United States was at around 128.13 percent of the gross domestic product.
“The contrarian position isn’t that a recession will come later, but rather that it’s already started.”
According to Steve Hanke, the professor of applied economics at Johns Hopkins University and a senior fellow at the Independent Institute, thinks “a U.S. recession is baked in the cake.”
“Due to the Fed’s monetary mismanagement, the M2 money supply is falling at its fastest rate since the 1930s,” he stated.
“The QUANTITY THEORY OF MONEY tells us that, w/ a 6-18 month lag after M2 drops, economic activity will slump.”
https://cms.zerohedge.com/s3/files/inli ... k=mIKabONF
https://www.youtube.com/watch?v=2T4pH7F0x1A deny debase disrupt decieved
Real estate drawdown solution - REDS
Black Pool funding stirring the waters.
REITS products are staggering numbers as are auto repos.
No accurate accounts available to segments.
Data Fragility was warned. Velvit rope to rope burn.
https://cms.zerohedge.com/s3/files/inli ... k=akMTe2Z6
Performance is up 12.41% from April 17, 2020 to April 14, 2023
I did decline the bots offer to join. Never allow the sandbox in.
The mirror watched until the keys had been corrupted. Sold the licenses.
And thus it now makes sense why Nahum would ask “where is the lion's den.“
thread: amos
https://www.youtube.com/watch?v=Yf08EGAMIP4
No Such Agency
Tesla founder says it "blew my mind"...
https://www.youtube.com/watch?v=brLNe4UTmgM
"For in him all the fullness of God was pleased to dwell."
So yeah, they will close down the State parks, and furlough all non-essential .Gov people, only to give them all their backpay AFTER the republicans cave in. Uniparty dolts as they lie to you.
The kid will rot in jail for lies proven on the slides they did. Carlson is correct.
California DA who floated keeping gang members accused of killing toddler out of jail faces recall backlash.
District Attorney Pamela Price reportedly sent an email floating the idea of non-prison punishments for three gang members accused
of killing a toddler
https://twitter.com/MattWallace888/stat ... 96/photo/1
imbeciles of the week cubed
The party skank chick that went budwok was terminated as frathoe party pump as information went lets say exponotional in the actual real world.
The hold my beer call was correct and I should of shorted that retarded sector executuve sector. The point is simple the directors are assholes.
Another correct call on the 270 dumb asses was correct. The last check we are sitting as bears on the bone pile 5.9 percent as theta burns.
Thye have no collateral and a shortage of dollars. Believe what you wish on inputs and the current levaged dialectic swamp cults intetia
to sell your ass down the river.
https://www.thegatewaypundit.com/2023/0 ... ago-video/
No one demonzied them.
They did it all by themselves.
CNN will not cover this story.
NYTimes will not cover this story.
Adams in nyc will have you all on 21 meals per week of insects.
Reptile snake zone worshippers of kali and molek mutalators.
Ford’s words, Contemporary Amperex Technology Co. Ltd., or CATL, is “the world’s largest battery producer; their limited involvement will be as a contractual service provider and licensor of technology to Ford.” So Ford will construct batteries using technology controlled and licensed to them by a Chinese.
Told you that your clueless fools and still are.
As the company dwindled, its new CEO oversaw much of the most profitable assets being transferred to Chinese-linked Neo Materials, where he formerly served as CEO as they final remaining husk declared bankruptcy in 2014. Unsurprisingly, the majority of Neo Materials’ revenue-producing operations are now in China. To make matters worse, the mine was purchased out of bankruptcy by a consortium that included a Chinese-owned firm.
The market was sold at a loss and they own your stupid asses as they collapsed material input prices as your swamp assholes looted it.
EV will finish you retrograde fools. You allowed inputs to fail and now the demsheviks own your stupid Balaam ass riders.
https://www.zerohedge.com/political/mtg ... ip-chinese
Failed in life try hell so yea filth covers it as it hardened as you had been warned. Idiots.
Your agency issuee went way over the wire. Taxpayers know your just evil corrupted retards.
Users browsing this forum: No registered users and 16 guests
