02:35PM Atlas Pipeline downgraded by Barclays Briefing.com
01:38PM Why Not Purchase This 7.5% Yield MLP For The Long Term?
As for the near term integrations in key profile areas of “Behavioral Economic Engineering and Social Cognition”.
at99sy
Post by at99sy »
Higgenbotham wrote:sy, a few years ago, I mentioned this.
http://gdxforum.com/forum/viewtopic.php ... hood#p8107
The book is no longer in print (I still have a hard cover copy). Used copies are still available.
http://www.amazon.com/The-Silent-Brothe ... 0451167864
I just ordered the book from Amazon for $4 delivered. This is very likely the same group we talked about. I joined in 1984 but didn't hear about it until somewhere around 1986. But those I mentioned could very well have been a splinter group or supporters. But it fits nicely into the fantasy scenarios we used to come up with for taking down the US and how to defend against them. The energy grid and financial networks were then and are now the most vulnerable.
http://gdxforum.com/forum/viewtopic.php ... 3280#p8095
Not much has changed but the subtle irony of California just maybe being a dust bowl does indeed appear that the universe indeed has a sense of humor.
“Those whom the gods wish to destroy they first make mad.” Euripides
- Lovers of themselves — check
- Lovers of money — check
- Boasters and proud — check
- Blasphemers — check
- Disobedient to parents — check
- Unthankful — check
- Unholy — check
- Unloving — check
- Unforgiving — check
- Slanderers — check
- Without self-control — check
- Brutal despisers of good — check
- Traitors — check
- Headstrong, haughty — check
- Lovers of pleasure rather than lovers of God — check
- Having a form of godliness but denying its power — check
I think that about sums it up. 2 Timothy
The last lay off wave touted "well, I will just go on the Obama plan"
That was the answer I got then. http://www.opencongress.org/bill/s2544-110/show
How soon we forget what we seen.
Therefore he who is prudent will keep silent in such a time, for it is an evil time. Amos
Disinformations mimic prevailing preconceptions which contain their own camouflage. Moreover we see such deceptions rapidly
become entangled and fused with the bureaucratic interests.
http://www.khpg.org.ua/en/index.php?id=1221299499
The Resolution “On the protection of property of State enterprises, kolkhozes and cooperatives, and the consolidation of socialist property”.
http://solarcycles.net/2014/02/20/max-short-equities/
He says max short equities. I'm still 25% short the Nasdaq 100 but getting ready to move to 50% tomorrow if things look right.
From last weekend, I had a projected target of 3683 posted on the chart of the Nasdaq 100. It hit 3685 Tuesday and has come down off of that, but not by much.
For the Nasdaq Composite, I had thought it might reach toward the late 2000 attempt to get back to the high. It came within 12 points Tuesday. There was an attempt to break a low down at the 2009 bottom that came within 12 points of the 2003 low. That's also drawn in on the chart.
Nobody that I know of is talking about the Nasdaq, but in my opinion that is a critical issue. Maybe not the only one, but an important one.
The chart below is an update of where I see the critical levels on the Nasdaq Composite possibly coming into play now.
If the Nasdaq can't clear that level there will be plenty of time to get short. The key for me is whether it does or doesn't. So far it is having trouble with it.
http://maidantranslations.wordpress.com ... r-killers/
I opened a short also. IMO march4 and after is my Smashed Crystal Ball view. In a longer view we already stated "it begins"
Kiev will flow in human misery. There will be no vote I observe also. The market will be irrational longer than solvency in zones.
One ton per acre lime was already added for this spring window.
Basically we have seen the obvious in nominal terms also.
It is very naive to expect that technical improvement in efficiency will lead "per se" to lower consumption of energy.
The truth is that sustainability is not a technical issue, but a cultural one. The behavior of complex systems from a
steady state perspective is unwise and unsafe and unmitigated folly for simple of lacking a human knowledge base. ggs gd
base three measures will not be denied
aedens wrote:I opened a short also.
I moved it up from 25% to 50% short at the close, and switched into ES since it closed down on the week whereas NQ did not. This is the first time I've been 50% short since early November.
The Dow is making the same pattern it did in 1929 but is taking a few days longer. Note the 2 probes up toward the red line (from underneath, after it headed down below it) and the rejection in both cases. The second probe up toward the red line was today. Also, in both cases, after breaking under the red line from the top, the Dow moved down 9 days before reaching a low and heading back up toward the red line. The red line is drawn from the low between the 2 highs at the top. When silver broke down in 2011, it also tested the low between the 2 highs before it broke down.
Here are some follow up charts to the Nasdaq Composite and Nasdaq 100 charts and comments from last weekend. The targets have been hit pretty closely and rejected with a down close today. But they didn't really go down a lot from the highs of early this morning.
Annotations added.
https://twitter.com/search?q=%23Ukraine&src=hash
http://unitedstateschat.net/index.php?news&nid=12
https://www.facebook.com/photo.php?fbid ... =1&theater
Europe’s new battlefield
Lamestream notes tonight flyover Americans are politically unsophisticated on issues.
Cannot they see we have note taken but are to corrupted to look under the sheep skin?
My plan for your future has always been filled with hope. Jeremiah 29:11
Pray for the slain on this sad day.
Evil men will think that it is strange that you will not associate with them. They assume that you think you are better than they are. You are better. A sinner is better than an evil man!
You are indeed too good to run with them! The wise thing for you to do is to worry about getting your sin forgiven and not to speak evil of what you see or hear about somebody else.
Where are you in the progression of evil? I have only learned of one place on earth that at his cross he paid the price for me also. At least the founders understood that maybe over
time the three bent of minds will slowly walk away from evil at least under a Union and indeed they warned us in advance.
